Old 17th October 2008, 04:40 AM   #1
Default Crossover Help
Can someone please help me to understand this crossover design in the picture. Low pass is set at 1.2kz and the high is 3khz. What about the frequency range from 1.2kz to 3k.
It's a highly touted design that i saw from the threat here at audiokarma:
http://www.audiokarma.org/forums/sho...d.php?t=150939
Thanks in advance.
Old 17th October 2008, 07:12 AM   #2
infinia is offline infinia  United States
infinia's Avatar
Hi
Crossover is at 2.5KHz... the tweeter and woofer sum around the crossover range
tweeter input is Vn002
Woofer is Vn0006
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 17th October 2008, 08:24 PM   #3
Does that mean woofer has to play up to 2500. I still dont understand how it can in do that. I need to learn more about these things. thanks for your explanation.
Old 17th October 2008, 09:44 PM   #4
infinia's Avatar
Yes... at least to a minimum. Since the filter response shown by the Xover circuit by itself sums almost perfectly, then both drivers should be ideally flat around the Xover region and beyond.
FYI The total response of the speaker is... the bass drivers response in box times the LP filter response summed with the tweeter and wave-guide response times the HP filter response.
This is a math/theory viewpoint. IMO The art here lies in seamlessly matching the final LF+HF off axis responses (i.e. similar directivities) at the crossover point.
Old 17th October 2008, 10:05 PM   #5
tinitus is offline tinitus  Europe
I dont know which woofer is used, but a few things matters in respect of the "big" series inductor
One is BSC, which means output will be lower below 500hz and is compensated with "attenuation" of higher midfrequencies
Further, your highly effective woofer probably shows a rise in both output and impedance above 1khz, which results in a delay before te xo slope sets in
Old 17th October 2008, 10:38 PM   #6
infinia's Avatar
Not sure of your point here...
Is it concerning that a 95 dB/W woofer is now just an average 89 dB/W just before Xover point? (then requires attenuation of an efficient tweeter/waveguide design by up to 18 dB).
The rise in output is due to beaming (cone design) which can be useful in matching a wavequides directivity, but a rise in woofer impedance and delay can be absorbed into the Xovers LP filter circuit (see my previous attachment).
Old 18th October 2008, 05:31 AM   #7
Interesting, most 15" woofers are not designed to go up to 2500 so I thought the cut off low frequency drive for "econowave crossover design" in question would top out at 1200. I am more confuse than ever. Anyway, many thanks for your help
Old 18th October 2008, 10:18 AM   #8
infinia's Avatar
Yes, I also think the 2,500 Hz Xover is too high for a 15"... but I don't have any other details either. The crossover seems to be for a generic 2way ...more useful for a 5" to 7" & 1" dome i.e. 2nd order with full BSC.
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Help me with a crossover. raypalmer Multi-Way 4 5th April 2009 01:48 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 09:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.13479 seconds (75.66% PHP - 24.34% MySQL) with 11 queries
