I was running some alignments the other day in Win ISB and I thought that since we are able to approximate an IB loading with an aperiodic enclosure. What would be the ideal driver parameters for low bass extension and good transient response for this type of enclosure. I modeled a few drivers with high qts. One that had a qts of around .80 had amazing extension. But I can't remember the driver model off hand. Even better than an ideal driver in a BR alignment.
Normally a driver like this would require an OB mounting or a huge sealed or BR cabinet. But what about a cabinet of average size with a large enough resistive vent to approximate an IB size of enclosure. |
#2 |
Can we also approximate an OB model in WinISD?
#3 |
I don't know. The way that I approximated the response was to define a closed box with a huge cabinet. One that would actually be too big to realistically build. Cabinets with 30-50 cubic feet of space or more. If you had a large enough baffle I suppose you could approximate the driver loading with a huge sealed alignment but I think that baffles of realistic widths would nullify the approximation since cancellation at lower frequencies would not be considered.
#4 | |
It does not work like that, you end with a small open baffle with no bass. A resistive opening can increase apparent box volume therefore reducing box Q, but the output of the resistive vent is out of phase with the main driver cancelling some of its output. It works for marginally too high Q sealed boxes -> aperoidic. THe Q is lowered and some of the peak bass output is reduced. Overdoing it, it simply stops working. |
#5 | |
Designing a maximally flat impedance TL with an Fc that blends well with room gain seems a simple way to do and has the advantage of a ~flat phase response, something the IB can't do. For example, a theoretical 13 Hz Fs driver with a 0.5 Qts and 20 ft^3 Vas yields a reasonable 10 ft^2 cab. L = 127" CSA = 136"^3 Sim assumes 0.708 lbs/ft^3 stuffing density of polyfil. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
Impedance and phase:
| tuning aperiodic vents | the full ranger | Multi-Way | 9 | 18th November 2009 09:22 PM |
| Ideal power level to suit a driver? | Pbassred | Multi-Way | 0 | 27th April 2009 03:27 PM |
| Ideal volume for two Vifa Pl18 driver | andy2 | Multi-Way | 0 | 26th December 2005 03:24 PM |
| What is the ideal sealed qtc? Anyone have luck with an aperiodic setup? | GuyPanico | Car Audio | 11 | 25th May 2005 08:14 AM |
| Ideal cone excursion at box tuning freq. | Circlotron | Multi-Way | 14 | 23rd September 2003 01:07 PM |
| Page generated in 0.11023 seconds (68.81% PHP - 31.19% MySQL) with 11 queries |
