Does anyone have the T/S parameters for the M&K sound Vifa A10CC-07?
Are they a good choice for OB implementation (mid+hi)? |
#2 |
#3 |
http://www.shoppluz.com/index.php?se...page=2&large=Y
Do you need T/S parametres for OB mid-range?? As cheapo mid-range?? If price is right?? Experiment!!
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#4 |
The fact that the suggested ported enclosure only reaches 80hz makes me suspicious of its Fs.....perhaps it's 100hz or so, which would be OK, but things might start getting interesting if it was any higher.
#5 |
Yes definitely midrange only
#6 |
#7 | |
Peruse : http://www.quarter-wave.com/OBs/OB_Design.pdf 150Hz is not really an issue with the above approach. The price is certainly right if sourced from Apex Jr. http://www.apexjr.com/speakerstuff.html The PE 15" Pro Goldwoods are an option to go with them. http://www.parts-express.com/pe/show...number=290-394 |
#8 |
sreten: You might want to read merajsaleks posts over Bookshelf dipole speakers - is it possible ? to see what he has in mind
#9 | |
Thanks. An OB nearfield ? Not something I've seen much info on but I will say the baffle response will not be the same as farfield, you will get a lot more bass nearfield, how much I do not know. |
#10 | |
| Little help needed - Vifa MG18 + Vifa DX25 - 2.5way | guitvinny | Multi-Way | 12 | 10th May 2009 10:18 PM |
| new speaker for Vifa A10CC-07.... | Nanook | Multi-Way | 3 | 13th October 2008 07:32 AM |
| Page generated in 0.22969 seconds (38.22% PHP - 61.78% MySQL) with 10 queries |
