Old 17th October 2008, 02:07 PM   #11
GM is offline GM  United States
GM's Avatar
Originally posted by Buzzy
I think this is a great idea but i don't know how it will match with my mission m32i mains.
I can't put the single midbass and tweeter speaker vertically as i am putting it on top of my projection tv. That will make it look weird.
If the Missions don't image well enough to use phantom CC mode, then 'smart money' IMO with a big RPTV is to build three either co-ax or tri-ax HT only L-C-R monitors for mounting overhead. With a bit of shelving EQ to tone down their inherent 'shout', inexpensive car audio drivers work surprisingly well.
Originally posted by BHTX
I'm assuming there's some space underneath the screen then? Build a short stand, and put it there.
Note that mounted in front it must be shielded AFAIK, while up top they don't, at least that's the case with the older CRT RPTVs.
As always though, YMMV.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th October 2008, 03:52 PM   #12
sdclc126's Avatar
In my opinion the CC speaker doesn't need to "match" with the mains in an HT system, as it is dedicated to voice reproduction and the mains are for music. Having said that, a clean, low distortion speaker with proper filtering is desirable for all speakers in any system, and matching efficiency and output are important also.
Consider this design:
http://www.zaphaudio.com/audio-speaker18.html
I think a "soundbar" type CC speaker with a horizontal array of the Hi Vis could be considered, for systems where a higher potential output is desired, wired for proper impedence of course.
Soft Dome
Need center channel help Ryan_Mc Multi-Way 0 12th February 2009 03:36 AM
center channel?? wicho Multi-Way 1 25th October 2008 01:01 AM
T-amp for Center Channel? atleer Class D 3 6th August 2007 04:56 PM
center channel sidd_raj2002 Multi-Way 14 4th December 2004 02:41 PM
Center Channel bhg41088 Multi-Way 1 5th September 2004 01:57 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
