Old 14th October 2008, 09:38 PM   #1
Default Horn Speaker Efficiency
I'd appeciate some guidance on horn efficiency. What info I've been able to find suggests efficiencies of from 30% to 85% - so it could be anybodies guess!
I made my own-design wide-range horn and I reckon it's efficiency is 10% at most - probably less. I'd really like to know what efficiency it would be reasonble to expect and is there a theoretical maximum - or any comments.
Old 14th October 2008, 10:12 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Note that efficiency is frequency dependent because electrical impedance is not flat and 2.83V/1m sensitivity is not flat either. It may be as high as 50% for some frequencies and as low as 10% for others.
Try Hornresp software if you haven't got it yet.
I use to feel like the small child in The Emperor's New Clothes tale
Old 15th October 2008, 09:12 PM   #3
Isn't some generaly accepted working efficiency range for horns then? In the same way you'd know the general efficiency for a relex speaker say, or a class A or class B amp - or D or G for that matter.
Thanks BTW, I've now got Hornresp - I'll give it the attention it deserves once the balsa dust has settled.
Want to go high efficiency... need some horn advice nobody special Multi-Way 8 6th July 2007 08:56 AM
A question about back loaded horn efficiency BHD Full Range 13 13th December 2006 07:15 PM
horn-loading: 100% efficiency ?! e-side Multi-Way 54 1st August 2006 02:42 PM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 11:30 AM
High efficiency 2 way using Eminence Alpha6 + Horn tweeter BlackUnikorn Multi-Way 9 16th April 2004 10:19 PM
Page generated in 0.12250 seconds (53.42% PHP - 46.58% MySQL) with 10 queries
