Old 14th October 2008, 03:13 AM   #1
Default dynamat for lining inside cabs
hi all
ive got a pack of dynamat extreme sound deadener
and im planning on lining the inside of my speaker cabs with it
its got a layer of bitumin with aluminium over it and im wondering if it would be suitable
its great for deadening the walls but im concerened the aluminium may reflect the sound and standing waves around the cabs
any advice on if it is suitable or not would be much appreciated
cheers
Old 14th October 2008, 12:02 PM   #2
Sealed boxes stuff, vented line with foam, the damping will not matter.
That is : physical damping of the wall resonance does not effect the
damping of the airspace resonances, and vice versa.
/sreten.
Old 14th October 2008, 11:32 PM   #3
thanks mate
the cabs are made from 4x 9mm flexyply with a 3mm sandwitch of mdf in between each layer ,they are also curved so i guess the lining will not be required
i had a full pack of the dynamat extreme just sitting there so i thought i might use it if it would help
How do you secure your cables inside your cabs? dublin78 Multi-Way 15 13th March 2008 09:26 PM
Why Dynamat? subwoffers Multi-Way 1 15th January 2008 10:37 PM
Tannoy 15" Reds for sale with crossover and cabs (local pickup for cabs) saletel Swap Meet 0 27th October 2006 10:01 PM
Lining inside active subwoofer JDeV Subwoofers 4 17th January 2003 12:07 PM
Page generated in 0.09271 seconds (61.97% PHP - 38.03% MySQL) with 10 queries
