Hi all,
I am planning to use and make a bass reflex box with that speaker; http://www.tb-speaker.com/detail/1208_03/w5-1611sa.htm Last weekend I had a chance to listen it with a ~18lt bass reflex box. The basses and mids were really good for a fullrange speaker compares to other ones (I have listened several full range speakers in the same place).. However I felt some lack of treble details, especially for the high trebles... Then I think that it will be good idea to add him a tweeter like that; http://www.swanspeaker.com/product/htm/view.asp?id=23 Both of these speakers are good to me because theyre available in a local seller and already listened by me.. So... If I use that tweeter will work with W5-1611.. What kind of crossover should I use? These are my ideas, - Just a 12dB/oct high pass filter for the tweeter works @15Khz. - A 12dB/oct crossover works @10Khz. - Or a standard also 2nd order 2 or 3Khz crossover.. Which is the best solution? May you give an advice to me pls? Thx in advance.
Best regards, Ozgur |
#2 |
No advice?
#4 |
Try crossing it over high to avoid any tweeter distortion. You can try first order series if your not bothered about BSC. To add some BSC a first order parallel is simpler. Use a series inductor to balance the midrange. |
#5 |
The bad news is, I dont know how to calculate a BSC filter
So I will try just a first order HPF for tweeter (1u series makes ~15Khz HPF for this tweeter..) But after the box complete of course.. Thanks..
#6 |
Soakin' up the Sound!
Dxvideo,
here are a couple links about BSC. http://diyaudioprojects.com/Technica...it-Calculator/[URL=http://diyaudioprojects.com/Technical/Baffle-Step-Correction-Circuit-Calculator/] http://sound.westhost.com/bafflestep.htm
#7 |
Many thanks...
I will make a BSC for him..
#8 |
That calculator (and nearly all others) ignores the effects of driver inductance. |
#9 |
A stupid question;
Does the snubber on the amplifiers output do that function also?
| Tang Band W5-1611 Question | Dxvideo | Full Range | 5 | 15th March 2010 08:35 PM |
| Tang Band W3-593SF vs. Tang Band W3-926SD | Zaputh | Full Range | 17 | 5th June 2009 11:37 PM |
| Tang Band MTM ? | wrenchone | Multi-Way | 11 | 21st November 2007 06:39 PM |
| 8 x 12 Tang Band | troystg | Subwoofers | 3 | 2nd February 2007 03:37 AM |
| Tang-band 2-way (W3+W8) | haffe | Multi-Way | 10 | 31st January 2007 11:11 PM |
| Page generated in 0.13135 seconds (69.55% PHP - 30.45% MySQL) with 10 queries |
