Old 11th October 2008, 07:24 PM   #1
weinstro's Avatar
Default Distortion characteristics for Peerless paper & poly drivers
I purchased a pair of Peerless 5" drivers, 830860, for the purposes of constructing a small MT satellite for use with HT rig.
I've looked at some test data on Zaph's website for a similar driver with a Nomex cone (832873), where nice FR and distortion curves are shown. One can use this information to make informed decisions on crossover frequencies. However, to the best of my knowledge, similar data for the poly cone variant of this driver is non-existent.
So, what's a guy to do?
What I'd like to ask this group is given a particular distortion curve for a driver, what should I expect the distortion curve to look like (and the harmonic spectrum), if only the cone material is changed to polypropylene?
The other alternative is to find someone willing to test the driver, or go to the garage and spend some time building a test rig. The latter approach might require more talent to get right than what I possess.
Thanks.
Old 12th October 2008, 05:07 PM   #2
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Default Re: Distortion characteristics for Peerless paper & poly drivers
Thanks.
I bet you can expect very similar performance. I don't own a pair of those, or I'd test them (I own Praxis). It's probably not worth the cost of two way shipping to figure it out either...but if you want...I can test....
I've tested the Peerless CSX range drivers, very linear, very good motor structure. The one problem I had with them is that they did NOT handle overload gracefully...they would survive, but the sound would go from pristine to eegads what was that...in a hurry.
Scott
Old 14th October 2008, 01:55 AM   #3
If you are talking about the current HDS lines, the main difference-other than the cone- is a better and better motor. Being at the bottom of the HDS line, I don't believe the poly cone drivers have any shielding/shorting rings in the motor. I would expect higher distortion than the Nomex series you seen at Zaph's site, and much more asymmetric impedance with excursion. OTOH I'd also expect a very smooth response.
~Brandon
DriverVault Soma Sonus Old Driver Tests
Old 14th October 2008, 03:12 AM   #4
As part of the HDS series, I believe they do have the shorting rings (as did the CSX drivers of old). Plus I cheated before I wrote the post and checked out Madisounds site plus the Tymphany site...
Scott
Old 14th October 2008, 03:27 AM   #5
weinstro's Avatar
Scott
Hmmm. The website descriptions are confusing. I've sent Tymphany an email requesting clarification. I was hoping that the only difference was the cone material.....crossing fingers.
Is there anyone nice enough to offer to run a distortion test?
Old 14th October 2008, 03:59 AM   #6
Scott
Yeah you may be right. The Tymphany info is confusing. I thought for sure the PPB drivers had higher inductance than the Nomex but looking at Tymphany's info they are both pretty low, with the PPB being a hair better. But the Nomex says shorting rings in the description so maybe you'll only see the difference with an impedance measurement at various excursions? The Exclusive mentions copper which I take to mean a copper plated pole piece, and if you have ever seen the Exclusive's impedance at xmax it's pretty clear that's what it is. So I dunno.
~Brandon
Old 5th May 2009, 05:27 AM   #7
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
I believe both the poly and the Nomex HDS drivers have Aluminum shorting rings, and, are quite low distortion. I prefer them over the "Exclusives". Both in appearance and for their smoother frequency response.
The 5.25" HDS can work in a very small cabinet, and the 6.5" ones should make very nice two way speakers, but in a larger cabinet - still, not so large compared to some other woofers...
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 2nd June 2009, 01:41 PM   #8
GWEE is offline GWEE  United States
sorry for the jack but i tyed makeing a new thread, but it wont let me....
Hello all,
Im looking to build a pair of bookshelf speakers and would like to use Vifa XT25TG30-04 /Peerless Nomex 832873 because of the fact i have then already. Has this combo been done before, i would need help with x-o design. If theres specs for a x-o pleae post a link to it.
Old 4th June 2009, 06:37 AM   #9
have you seen this design http://www.troelsgravesen.dk/Peerless_HDS830860.htm seems it would be a nice bookshelf to build. but could you use the 832873 and keep the x-o the same?
Old 8th June 2009, 10:37 PM   #10
critofur's Avatar
It should be decent. I suggest building it, and, if it doesn't sound quite right, you can always ask for some suggestions for tweaking the crossover.
I would build a pair of those and measure them, but I don't have either of those types of Vifa tweeters.
I have at least a dozen of the woofers [Nomex], I had been eyeing them for years, and jumped at the chance to get some cheap.
Oh, I happen to have a pair of the PP ones also. At some point I will build two pairs of speakers which are identical, except, one will have the Nomex and the other will have the PP woofers.
Critofur
Paper v. Metal Cones: Subjective Sound Characteristics Karl71 Full Range 38 28th June 2009 04:57 PM
P13WH00: Poly Cone or Treated Paper/Butyl?? murat Multi-Way 1 3rd November 2007 11:40 AM
Seas poly or paper? Ap Multi-Way 4 27th March 2006 11:08 PM
lambda poly cone vs paper Austin Multi-Way 6 6th December 2002 08:10 PM
Page generated in 0.16878 seconds (67.82% PHP - 32.18% MySQL) with 10 queries
