#91 |
Hey Lynn,
Contrary to what you have been told, the Classic Audio Reproductions T-1 is **not** the brainchild of Dr. Edgar. The cabinet work and product concept has always been done by John Wolf of Classic Audio Reproductions and he also defines the spec for the speaker. The woofer and midrange drivers are a collaboration between him and Sam (whose last name I don't recall right now, but is the country's leading field coil expert) and they (with a very slight amount of input from me) did the crossovers. Dr. Edgar designed and did a partial build on the midrange horn (John did the rest), at Sam's suggestion (I'm told). The tweeter had the most input from Dr Edgar. I agree with Jonathan Valin- this speaker has transformed more than any other speaker design out there (and in only a year) and IMO is better at showing what horns can do that just about anything else, despite being a bass reflex (albeit a very well-behaved bass reflex, owing a little to the fact that the second woofer is down-firing). I know of no other speaker that is as full-range, easy to drive, easy to set up in the room that is simultaneously as transparent and detailed. The room we had at RMAF, Salon A of the Evergreen Ballroom, is (I hope) obviously not the best place to show the speaker as it is quite reverberant; in addition the presence of the Hartsfield Reproductions right beside the T-1s didn't help a bit! In a more normal room setting the speaker is hard to fault by any standards. Yeah- I bought a set |
#92 |
Thanks for the update and backgrounder on the new T1's.
From my perspective, the crossover designer is the real author of the speaker, since the crossover is where all the "voicing" and design priorities are expressed, and is also the most time-consuming and tedious part of the design. Full credit to John Wolf and Sam for ditching the TAD driver lineup and going with the field-coils. New drivers, new crossover, new speaker. |
#93 | |
The Orions did not impress me at all. In fact I'm rather bummed that they were so ordinary. Not very dynamic, nor life-like, nor musical. Well controlled, yes - but maybe too well controlled. Seemed to be a problem with so many OB systems this year. The Pluto, however - was great fun! And Mr. Linkwitz is very gracious and intellegent. Sorry I didn't care for the Orions... I did hear the big RAAL omni rig, even played my test cut on it. OK, but a lot of problems. The sections didn't intergrate well to my ear. However, there was a small speaker from Serbia that I think had the RAAL tweeter - I liked it a lot. Think it was SOLAJA AUDIO.
Take the Speaker Voltage Test! |
#94 |
Yes, I heard them - they were just down the hall from Alexander. Beautiful woodwork, non-intimidating moderate-sized speakers with Audio Technology midbass and RAAL tweeters. A great combination, smooth and silky, with a lot of charm to the presentation. Nice speakers.
Listening to Alexander's tweeters sort of spoils you for the usual run-of-the-mill Vifa/Scan-Speak/Seas 1" dome tweeter, doesn't it? Just like DHT triodes, it's hard to go back. There is a weird thing going on with a lot of high-end "standard-efficiency" speakers - they can be very picky about the recordings you play, particularly vintage late-Fifties recordings. A vintage recording - say, RCA Living Stereo or Mercury Living Presence - can sound absolutely glorious on a well-tuned horn system, thrilling, exciting, with lots of shimmer and sparkle, and most all, an almost tactile you-are-there presence. You can hear this before the music starts - the space is filled with a sense of presence, of expectation, of people moving around. This same recording can sound flat, dull, and technically deficient on mainstream high-end speakers - and in a show environment, I had an exhibitor rudely cut off my selection and hand it back to me, and return to the usual audiophile demo stuff. The "Press" badge only goes so far if it doesn't say "$tereophile", "Absolute $ound", or "$ix Moons" on it. Thanks to my exposure to the Colorado gang (big shout-out to Thom, John, Steve, and Orey here), I've lost patience with this sort of cranky hifi system. If it can't deliver musical satisfaction with recordings of great performances - forget about the recording quality! - the system just ain't hifi, no matter who designed it or how much it costs. |
#95 | |
could you specify a littlebit more, what you specially liked on the new T-1's ? I don't know if you heard the previous model with TAD drivers. Which main improvements did you observe with the new model ? what makes speakers, employing FC's , sounding so much better ? I have read a lot of good things about FC drivers. Cogent's, Shindo Latour, some say these belong to the best speakers, they heard. At the first auction ( post Nr.8 ) i saw on ebay of a Altec 288 converted to field coil, the seller gave some interesting insights. Do you think the mentioned advantages are the main reason for the good performance? Is Sam the seller of the converted Altec's on ebay ? The field coil feeds its magnetic field by a direct current. As long as the current is constant the field coil must be constant. Thus the field coil can produce stable and uniform magnetic field. Nowadays, we have advantages compare to the old TUBE days to acquire a quality DC power supply that is regulated, stable DC voltage, no hum (no need to use the bucking coil) and affordable that can be used to supply direct current for the field coil. On the other hand, while the AlNiCo or any permanent magnet speaker during active mode (playing) can not be able to supply a stable or uniform magnetic field continuously due to the atoms or molecules randomly change their magnetic poles then trying to self-align again to gain the total strength. This is a reason why the vibration of a diaphragm is out of control and produces a tremendous amount of unexpected high pitch due to unstable Magnetic Field. You may confuse the high pitch and its loudness with the desired high frequency reproduction. This unexpected high pitch may upset your ear, like someone scratches his fingers on the black board. However, AlNiCo speakers maybe appropriate using at Techno Dancing floor where young people just care about loudness and extreme sound. The strength of magnetic field is not difficult to conquer by FIED COIL as long as we can deal with heat. The UNIFORM and STABLE Magnetic Field takes a very important role in the process of defined sound reproduction. I agreed the models AlNiCo Altec 288 (288, 288B, 288C, 288G, 288H, 288L, 288-8K, 288-16K) and also IPC, 291-16A, 299 and early 290 are sensitive, clear, presence, detail and “loud” (plus noise too!) similar to the famous JBL 375 AlNiCo that is a renovation of the famous WE 594A field coil. However, the 288 series and JBL 375 has a serious sound defect at the peak of the sound wave when diaphragm moving to the peak (the farthest distance from at rest). This high pitch noisy sound makes many listeners are confused between the “LOUD” high frequency noise and the desired music of “WARM” high frequency reproduction. In the other words, AlNiCo driver produces distortion that you can realize when the diaphragm moves to the peak. The sound is “cracked” like “a tip hair has split end.” The cracked sound may reduce 30% to 50% when couple with horn especially to the ALTEC 311-90 horn because of the air pressure changing smoother than without horn. Incredibly, The Field Coil Magnet amazingly solves this problem even without using any horn. |
#96 |
If the subject is going to drift at this point onto field coil power supplies, I would be interested to hear people's thinking as to whether constant current is most important or constant voltage. This is a subject about which I am very ignorant, but I do know from my experience with Feastrex field coils that the power supply definitely has a big influence on the sound.
-- Chris
"Avoiding deportation from Japan for over a quarter century!" |
#97 | |
Yep, those were the ones. Nice speakers and they didn't try to be what they are not. Very enjoyable. If I didn't build my own stuff, they'd be high on my list. There is an amazing amount of information that gets onto just about any recording, LP, CD, cassette even. A great speaker will let you hear it - and feel like you are there. For me it's a real adventure with each recording. Too many Hi-Fi rigs just "sound good." FWIW, I posted my impressions of the OB rigs I heard over on AudioCircle. http://www.audiocircle.com/circles/i...?topic=60599.0
#98 |
I think OB speaker like conventional baffle needs good electronics to work... You can ruin the performance of your loudspeaker if you didn't take care to the environment (source, amplifier).
It could explain some disappointment about Orion speaker, the system is quite complex, if you put a poor performance amplifier for the midrange, the sound could be very annoying. |
#99 | |
Maybe these same folks would have been more impressed if the ATI amp was located in the closet or the speaker cables were known to cost $4k/meter. |
#100 |
Hi mac,
I think audiophiles definitely know what sounds good to them. Have you noticed how they can wax lyrical about it til the cows come home? Reviews that go on for pages and pages. All kinds of flowery verbiage. What I suspect they don't know is what real unamplified music sounds like. When one writes a concert review the same vein as one would write a loudspeaker review, then we'll see... |
| Page generated in 0.15105 seconds (91.27% PHP - 8.73% MySQL) with 11 queries |
