Hi guys
i had a chance to demo a pair of talon hawk (retail $9000). i had to admit it has its own class. very fluid. details and very very natural.
but i am cheap lol, is there anyway to improve my diy usher design(cost less than $1500)?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=121079
the usher feels abit heavy and abit harsh? thanks jay for this superb speaker for only a fraction of the price of SUPER high-end speaker.
my questions: what contribute most to naturalness and super smooth sound?
1. passive crossover component play an important role? capacitor? resistor? wire? binding post? which one play most important part?
i am using mills resistors, obbligato caps and foil inductors(some from ebay, some are alpha core inductor), neotech and vampire wire, but ordinary binding post. or any better suggestion?
how bout boutique components such as duelund caps?
2. or the crossover design play more important part than component above?
3. will active crossover bested passive crossover?
4. speaker choice more important? i am using usher 8945p and 9950
thanks for the suggestion
milen007 said:...my questions: what contribute most to naturalness and super smooth sound?
1) Crossover design far more than components. Speaker cable must be thick enough to not offer resistance, other than that nothing. Binding posts, irrelevant - the best connector is no connector.
"Boutique components" - avoid - big waste of money.
2) See answer to #1.
3) Probably not; in any case you will then need additional amplifiers, adding to cost
4) Yes - most important - and you are using very good ones.
http://www.talonaudio.com/products/images/Hawkstand.jpg
Those Talons use Accuton drivers which are expensive and sound excellent. I have heard them in other speakers and they always sound superb. If you want that kind of sound you need to use those drivers. They are available at Madisound:
http://www.madisound.com/manufacturers/accuton/index.php
Put your Usher's up for sale and save to build a Talon clone. For speakers using crossovers (typical two and three way designs) I think Accuton drivers are probably the best. Very liquid and smooth sound, agreed.
Erwin,
I strongly suspect that the difference you hear between the Talon and your 2-way is simply the difference in their tonal balance. I really don't think the Accuton drivers in the Talon have lower distortions than the Ushers. I also don't think the Talon use a better crossover topology (like 1st order transient perfect) than your 2-way's.
You didn't compare the Talon and your speakers side by side in the same listening room, did you? If you want to compare two different speaker sets, you need a long term listening test in an identical environment.
If you email me with your preferred direction of change in your speakers' tonal balance, I may be able to let you know what kind of change you want to try.
-jAy
-jAy
Hi Jay
its indeed on my systems in the same room. In A/B comparison for 3 hrs, but will have friend coming tonight for A/B (possibly blind test), Talon Hawks does show its price. BUT..... usher is not far behind. my impression, the Hawks only a tad somewhat smoother and has a tad more detail as well. but the naturalness of the decay and maybe tonal balance does beat the usher.
i think that the usher need more tweaking to get its best.
the talon with its tag price sure has tons of tweaking. maybe thats the price to pay for.
Hi sdclc126,
whats the ideal gauge for crossover? i am using solid 18ga for tweeter and stranded 14ga for woofer. while from binding post is around 14ga as well. i might try bypass the binding post to see any improvement. I did plan not using binding post but the application not allowed that i cant make good connection without the binding post.
Hi Godzilla
I will check it out and put on my wish list for my next (if i do not manage to tweak my usher). do you know exactly which woofer and tweeter is used in Talon Hawks design? thx for the suggestion
Hi sdclc126,
Hi Godzilla
Hi milen007,
There is really no "ideal" gauge for crossover interconnects, but if you look at how thin the connector wires actually are on components such as capacitors and resistors, that will give you some idea as to how thin you can go with no negative effects. What you're using right now is fine - going any heavier gauge won't make any difference.
Let me clarify about binding posts - I'm not recommending you don't use them, it's just that you won't hear a difference between different types with different materials, etc., and you won't hear a difference either between using them or not. "The fewest connections possible" is simply a sensible guideline - don't use more than you really need.
My 2 cents about Accuton - very expensive drivers whose performance can certainly be had for less money. Accuton has placed a disproportionate emphasis on cone material when more of their engineering could go into motor design. Manufacturing the ceramic domes is very costly and that goes right into the retail price. Scan Speak has shown that good old paper, engineered properly and with the right motor design, has produced some of the best loudspeaker drivers in the world.
My advice about your listening tests - do them blind if you can - it's your best chance of eliminating your own bias and expectations when comparing one speaker to another. You might just be surprised.
milen007 said:Hi Jay
its indeed on my systems in the same room. In A/B comparison for 3 hrs, but will have friend coming tonight for A/B (possibly blind test), Talon Hawks does show its price. BUT..... usher is not far behind. my impression, the Hawks only a tad somewhat smoother. but the naturalness of the decay and maybe tonal balance does beat the usher.
There are some factors to consider:
1. Often times, perceived tonal balance *can* be a matter of personal preference especially for speakers whose designed frequency responses are not far from flat. Speakers can reflect their designers' own voicing preference, too. The "smoother" sound you hear might be due to the Talon's recessed upper midrange and lower treble. I'm not sure of its crossover frequency, but I suspect it is significantly higher than your Usher 2-way's 1,850 Hz. In my design, I prefer to use a tweeter's low-end response to create well-dispersed, clean upper midrange and lower treble. This makes the speaker's response in this range less affected by the woofer's beaming. Also this makes the speakers sound a tad bright and forward, which I like. If we use a higer xover point like 2.5 to 3 kHz, perceived tonal balance can be quite different even if the on-axis response is not that different.
2. Upon looking at the Talon's box and port, it is likely that its port tuning frequency is much higher than yours. If its sensitivity is really 88 dB, it means the designer uses much less baffle step compensation than I did in my design, and compensates the loss somewhat by the effect of high port tuning. This technique is used often by many speaker manufacturers (e.g., Klipsch). I don't like this since it causes a dip in the midrange. But the effect can be prefered by some people.
3. You got used to your speakers' sound. Right? Sometimes, people tend to find in other speakers what they miss in their own speakers. The opposite case can also happen: people don't like what their ear has not been accustomed to.
Simply using the Accuton drivers won't guarantee that you will have the same sound as you hear from the Talon, if the Talon sound is what you really want (not just for now, but for a long time).
After you compare these two speakers, let me know their difference in more detail. Not by general words like "smoother" or "heavier." Focus on tonal balance, for example, balance between bass vs midrange and between midrange vs treble. Also, within midrange, lower vs upper mids, and within treble, lower vs upper treble. Then I may be able to suggest some changes in the crossover.
good news guys.
usher 8945P and 9950 is highly recommended!!!!!!
after the crossover redesigned. all i can say is Superb!!! its alot better now. with run in around 4 hours, i can conclude that its almost or most likely matched the talon.
the only different is "maybe" the vocal in talon abit lay back. and
talon "maybe" image better.
however, the usher bass is stronger
all in all. this design is world class. thanks Jay for sharing. this is
really superb. way ahead my expectation.
happy listening
happy listening
it is a long process of fine tuning
most of the expense of a speaker is in the research and testing
just like what many of us do it yourself people are doing but not getting paid to do it
if you should get lucky enough to have some of the DIYer invite you to listen to their speakers and be tested under multitude of listening test that you have them do will give you the best for the least.
The most time has to be listening for the all aspect of true live performance reproduction quality is the main goal
knowing the harmonic nature and richness that defines the sound
what does a violin versus a oboe versus a flute versus a piano versus a typhamony drum versus a distorted guitar each of these are subjective and after all that it is what you can live with. For you may like it at the start but then it may have a quality that will come apparent after the time adjusting. For example my my ideology is to use MTMT in a LR2 XO and I have many speakers I will be trying to get my goal accomplished
I would disagree with that just a little
for you can have a perfectly flat frequency response but you can still have terrible imaging and bad acoustic detail
For we have to deal with pscyhoacoustics and multiharmonic detail in in the very wide of dynamic range and how the speaker project the sound. Plus each person situation is going to be altered by the room absorption and reflections.
I do believe that measurements are needed for finding and adjusting while working at the achieving the best results, yet they to are limited in what information and what information is best for listening.
For it would be easier then just to use headphones and not use speakers at all. For no room, multi-speaker interaction, correct phase.
hi guys
thanks for the inputs.
looks like this is not an easy job aye? maybe we can start building fullrange crossoverless huh? guess building a correct enclosure also a challange huh?
yeah, i think i have been tweaking my xo for more than 20 times. and somehow i still think there is something not right. especially when there is a room modification or changes.
halo Pak gainphile
what kind of measurement tools you suggest? clio? i do not have access on clio here in medan. i know one or two guys in diy community in jakarta have one.
hi mcmahon48
but using headphone is not my style as i feel like disconnected when i am listening. but its just me tho.
yeah i agree. room mods is pain in ***. i just install few curtains on my listening room and everything is just so different. pro and cons. need to adjust the speaker and my listening position as well. ggrggrgrgrgr
with with some absorber. HF is attenuated a lot in my case. arrgghhh thats why have to tweak again... never ending job... sighh... maybe just get a xo-less speaker and live with it lol
thanks guys for the inputs
erwin
halo Pak gainphile
hi mcmahon48
erwin
Re: I would disagree with that just a little
The key is to know what and how to measure, as well as knowing what to look for and its limitations too. We all don't have anaechoic chambers but there are ways to get around that.
As for room interaction, room problems should be solved with room solution. The speakers themselves should be as neutral as possible that's why I only do OB
Pak Erwin, no need for expensive tools. I use DIY mic + ARTA (free) and soundblaster card ($50). Something like this:
http://gainphile.blogspot.com/2008/11/cheap-and-accurate-speaker-measurement.html
mcmahon48 said:for you can have a perfectly flat frequency response but you can still have terrible imaging and bad acoustic detail
milen007 said:
halo Pak gainphile
- improving diy loudspeaker
