diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Home theater speaker - Advice needed (http://www.diyaudio.com/forums/multi-way/131050-home-theater-speaker-advice-needed.html)
Gollum 8th October 2008 04:04 PM
I've started to work on a dedicated home theater room in my basement. Things are going pretty good and it's now time to select a set of speakers to build. As you can assume, it will be the funniest part of the project ! With 2 sets already done (Zaph's BAMTM and Hi-Vi 3"), I'm ready for a bigger challenge : building a complete 7.1 (or .2) dedicated home theater system. So 7 speakers, all the same size, with one or two subs.
My main concern is, as you can expect, the seven speakers. I've found many designs for small bookshelf / satellite speakers that can be used as satellite, main and center channel. These things often have to be played 'small', with a crossover frequency set to 80 Hz at best, if not 100-150 Hz for some design using 4" drivers.
What I try to find is a design with enough bass extension to go as low as 60 Hz, but without losing too much on size, SPL, cost and wall-mounting capabilities.
Zaph's Bargain Mini is the perfect example of that : good design, but croosover point has to be set at 100 Hz if you want to have a decent SPL. Jay's RS180/Seas 27TDFC two-way design looks way better for bass extension, but cabinet size in vented version makes it impractical... so far, I'm unable to find the perfect match !
It's why I'm asking your help. Where can I find a good design that will meets these requirements :
- All 7 speakers will be the same size
- Nearly flat down to 60 Hz
- Wall- and ceiling-mountable (not too big !)
- With enough SPL to impress friends
- Cost for drivers and parts per speaker : not too much over 100$...
Am I asking the impossible ? I'm sure there is a good design out there using a 5 or 6" drivers with a 1" tweeter that will do the job for me. I've haven't found it !
Thanks for your help,
Dino
sreten 8th October 2008 04:28 PM
Jay is replacing that design with a SD Acoustics / Vifa design.
http://www.geocities.com/woove99/Spkrbldg/jays_blog.htm
:)/sreten.
Gollum 8th October 2008 04:48 PM
It looks good, very good in fact :
In a sealed 0.5 cu ft cabinet, this speaker's -3 dB point is about 62 Hz
I can't ask for more... Thanks sreten for the info ! I really appreciate it.
Someone else with another good design i'm not aware of ?
Jay_WJ 8th October 2008 10:43 PM
Dino,
I replied to your email.
-jAy
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
