hi..i am gonna make a loudspeaker with old westra speakers..they are made in germany and nowadays there are many made in china and low end speakers selling in my country..i am happy i find them.i am trying many speakers nowadays.but i couldnt calculate the cabinet diameters with programmes for westra kw200-1316 ..there is -717 liters the result of programme..do you think this parameters are true ?
Belatbarkeit: 70 W-RMS / 120 W-Max Impedanz: 6 Ohm Schalldruck: 86 dB Freuqenzbereich: 30-2000 Hz Resonanzfrequenz fs: 30 Hz Gesamtgüte Qts: 0,74 Äquivalentvolumen Vas: 69 l Einbaumaße: Außenmaße BxH: 202x202 mm / ø 200 mm Einbaudurchmesser: 185 mm Einbautiefe (incl. Korb): 90 mm Korbrandhöhe: 8,0 mm (incl. Gummiauflage) Gewicht: 1,1 kg does anyone have a ready to make box for my westra speakers?..thanks .danke schön http://www.hellsound.de/index1.html |
#2 |
here is the tweeter i will use . wdt-25-808 .it is very nice sounding silk dome tweeter..
#3 |
here is the bass driver
#5 |
i dont know..it is made in germany i think..
#7 |
What could be the tweeter's prize in US$?
#8 |
its about 25dollars now.not much
#9 |
but its silk dome and sounds very good
#10 |
the Qts looks quite high in value and so you can't use the typical recommended closed or reflexed box alignments for this woofer.
40l seems a good compromise to me. If you have access to cheap chipboard, why not build a test enclosure first? regards |
| Westra KW-200-1338: Usable drivers, or junk? | KozmoNaut | Subwoofers | 3 | 30th August 2007 11:46 AM |
| My 6,5" Westra driver? What can i do with it? | Dxvideo | Subwoofers | 17 | 14th March 2006 07:37 AM |
| A Pair of Westra XW-165-1394.. | Dxvideo | Subwoofers | 7 | 7th July 2005 05:46 PM |
| Page generated in 0.13139 seconds (63.91% PHP - 36.09% MySQL) with 11 queries |
