High-end 3 way dáppolito with aluminiumcone - Page 14 - diyAudio
Old 21st April 2009, 11:15 PM   #131
danieljw's Avatar
Send a message via MSN to danieljw
that software looks excellent, how do you find the sound of the three way with aluminium cone ?
-Dan
Old 22nd April 2009, 07:54 AM   #132
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
-Dan
The sound is very tight see the excellent waterfall result even the low frequency falls of very quick , with tight fastdynamic low.
And clean sound (not fat) low distortion see distortion results at 100dB on 1mtr.
I had two people to listen to both speakers the
fatboyproject and these.
One person liked the fatboy the other this one. After a while the opinion chanced to depends on music a taste of listener.
I have done some mods to the XO to improve flatness of the response at 300Hz and the tweeter. So I have to listen again.
Regards helmuth
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 22nd April 2009, 10:47 AM   #133
danieljw's Avatar
that project looks good too.
is the measurement software you used easy to use ?
Old 22nd April 2009, 04:38 PM   #134
Helmuth's Avatar
This project is a good loudspeaker for people how like response down to 18Hz with out having booming noise clean tight response. It reminds me of my back loaded horn.
Like often to start isn't any there is many to read and understand and calibrate.
Now i am through this firts start up it work easy the software give's sometimes warnings that aren't applicable that is a bit confusing.
You can download it and play with it first, before buying. The good thing of HBX I can get support from the designer Gerald.Matz himself through Email or the HBX forum. And they sell test microphones with calibration data that can be loaded in the testprogram.
hbx v6 download
To start with you can use free ware MLS software Arta 1.50 is free.
And audiotester v2.2 almost free. screenshots
Another popular commercial is lspCAD with the tool justMLS.
Old 22nd April 2009, 09:46 PM   #135
Helmuth's Avatar
I have bin busy implying chances after the first measurements.
The filter has now ref.C
Response:
Impulse
Waterfall.
Old 22nd April 2009, 11:34 PM   #136
danieljw's Avatar
thanks helmuth i will have a look at these software packages.
-Dan
Old 22nd April 2009, 11:46 PM   #137
danieljw's Avatar
hi helmuth the HBX^ looks very good but it is in german/danish ??
is it possible to change it to english thru a menu
(i cant read the menu to change it ??)
-Dan
Old 23rd April 2009, 07:57 AM   #138
Helmuth's Avatar
-Dan
It is German, for the V4 there is a English Help try that.
http://www.audio-software.de/downloads.html
Try the hbx forum and ask the designer Gerald.forum
Old 23rd April 2009, 11:00 PM   #139
Default Hey Helmuth
Very good job of redesigning there and I am very interested in you mic preamp, yet I am having trouble reading your schematic, would you redraw so it is more clear, I know how it is I do the same thing. Plus also I would suggest using a precision potentiometer in place of the multiple resistors. looking forward to using it with my Virtins spectrum analyzer program
what op amp are you using
Old 23rd April 2009, 11:23 PM   #140
danieljw's Avatar
thanks helmuth !
What to expect-converting to DAppolito ekaerin Multi-Way 1 24th August 2006 09:55 AM
Copyright ©1999-2017 diyAudio
