High-end 3 way dáppolito with aluminiumcone - Page 10 - diyAudio
Old 9th February 2009, 08:18 PM   #91
danieljw's Avatar
Send a message via MSN to danieljw
looks good helmuth,
I just finished my box work for the elsinore speakers... i have to putty all the screw holes now
at will you use to fill the holes / smooth the surface ?
-Dan
Old 9th February 2009, 08:41 PM   #92
frugal-phile(tm)
planet10's Avatar
Originally posted by Helmuth
bin in the garage and did some more work with the router. I have rounded the edges of the
panels en around the woofer.
Don't forget to relieve the back of the driver cut-outs for better air flow.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th February 2009, 09:53 PM   #93
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Originally posted by danieljw
looks good helmuth,
-Dan
I do not have to smooth the surface because I will use black speakercover cloth to cover the MDF front panels. It doesn't scratch and you won't see any fingers on it.
When you see the fatboy project there I have used velours to cover the mdf worked very good.
dave
Good idea but I am afraid the hammer nuts I use won't fit then.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 9th February 2009, 10:15 PM   #94
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Just mark the screwholes carefully, and leave the exstra needed wood around them
Anyway, routing the back does more good than the hammer nuts...even a relatively small rounding will help
sometimes we know very little, and sometimes we know too much
Old 12th February 2009, 08:07 PM   #95
Helmuth's Avatar
dave
Now I hope your pleased with the made cut out.
I also removed the little plate by bending them back.
Thanks for the tip Planet10.
Old 24th February 2009, 05:06 PM   #96
Helmuth's Avatar
I cover the front with black acoustic cloth that is better to prevent scratching and spots of fingers on glossy paint.
Close up
Old 24th February 2009, 05:11 PM   #97
Very nice
Old 24th February 2009, 10:02 PM   #98
danieljw's Avatar
Looks great !
Old 25th February 2009, 06:51 PM   #99
Helmuth's Avatar
Fits perfect the cloth fills up every edge. I glued in the bass reflex tube.
Old 25th February 2009, 08:10 PM   #100
Years ago I thought about the aproach with speakercloth
Only problem is that it really doesnt like dust
What to expect-converting to DAppolito ekaerin Multi-Way 1 24th August 2006 08:55 AM
Copyright ©1999-2017 diyAudio
