Hi all!
I have a pair of QLN Qubic 929AV speakers, which I use in my home theater. I have a QLN FS-600 center, and four Qln 122 as rear speakers. I think the rear speakers have a rather open and bright sound, while the main speakers sounds a bit dark and muddy. So I suspected that something in the crossovers had failed, and inspeceted one of them. It seemed ok, all components measured fine. The main speakers are rather large, has two 6,5" bass drivers, a 6,5" midrange at the top in a sealed chamber, and a 1" silk dome. The quality of the crossover components seemd ok, and the enclosure is also ok, with internal bracing and made from 22mm board. These speakers are about 10 years old, and not worth much, but if I could do something rather simple to improve the top/midrange I think it would be worth my while. Then i could spend some more on my dedicated hi-fi system.. The speakers are connected to a Pioneer receiver, and I notice that when i set the speakers to "small" they sound much better. I made a drawing of the crossover, which I enclose here, in case someone knowledgeable would take a look at it. All drivers are Vifa. I found the driver parameters online, but I`m not sure the parameters for the bass is correct. They are listed for the P17WJ-00-08 driver while mine is the P17WH-27-08, but it seems that several of the P17W drivers are almost identical. Gunnar |
#2 |
Basically there is not much you can do to change the overall balance bass to midrange other than make it darker which is not what you want. Looking at the layout they will sound bass heavy too close to walls. (as the arrangement implies full 6dB baffle step compensation) You could brighten the treble by reducing the tweeter series resistor and the lower treble by increasing the 3.3R in parallel with the midrange but I do not think that is what you want. This sounds somewhat radical but you might be better swapping about the drivers from your different speakers and tweaking the crossovers, assuming the other c/o's are similar and simple. Would the bass mid from the 122 be a drop in fit ? |
#3 |
Thanks!
I noticed the treble series resistor, but it is only 0.8 Ohm (R82). I could short it out just to try. I think they sound ok for movies, maybe because of the receiver EQ. Gunnar |
| Rane Crossover Modification | kbasaran | Parts | 7 | 18th September 2008 02:01 PM |
| crossover L-pad modification | Theli | Multi-Way | 7 | 26th January 2007 05:31 PM |
| Electronic crossover modification | qguy | Subwoofers | 16 | 8th January 2007 08:42 PM |
| electronic crossover modification | qguy | Multi-Way | 5 | 4th January 2007 11:54 PM |
| Crossover Modification | Jim McPherson | Multi-Way | 1 | 1st October 2005 05:05 AM |
| Page generated in 0.11611 seconds (59.11% PHP - 40.89% MySQL) with 11 queries |
