I am going to build a set of tower speakers using a set of 3 way components (Focal 165K3) and my plan is to use the passive crossovers from focal (24dB/oct. (300Hz-3kHz)) Now the tricky part is I would like to add a 10" or 12" woofer to each tower. I already have a Klipsch Reference 10” powered sub and would like the 10” or 12” woofer to fill in between the sub and the 6.5” Focal. Can I use the passive crossovers from Focal and buy a sub amp to power the 10” or 12” woofer using the built in crossover? What would be a good woofer to match the focals? I was thinking of the HiVi D10G 10" Kevlar/Paper Woofer only because the Kevlar matches the focal Poly/Kevlar cone. Here is a link to that speaker
HIVI D10G Any help would be appreciated Thank you If it matters I am tring to clone the JM Labs Grande Utopia Be's without the 15" sub in the bottom |
#2 |
Does any body know Hi-Vi D10G? Is it good to use it as woofer in a 3-way system?
#3 |
FWIW you can't clone a high quality hifi speaker by sticking car speakers in boxes. ![]() Simply put they are best used for what they intended for, in a car. rgds, sreten. FWIW though the 6.5" in a ~ 15L sealed and stuffed box should go low enough to cross over to an active 10" subwoofer.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 6th May 2012 at 02:16 PM. |
#4 | |
Hi, Its decent bass unit for a 3 way with a low x/o point to the mid(s). rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| Tower. Three way.. or two way w/sub | Christy | Multi-Way | 6 | 27th April 2009 11:22 AM |
| My most recent tower design | pjpoes | Multi-Way | 4 | 7th November 2008 09:49 PM |
| Dayton Tapered Tower Design? | BlueWizard | Multi-Way | 2 | 5th March 2008 02:43 PM |
| Ess Gas Tower 1.3 | Alex helge | Multi-Way | 18 | 26th October 2007 01:22 PM |
| Looking for tower speakers design w/ dual woofers | JojoD818 | Multi-Way | 16 | 28th November 2003 02:25 AM |
| Page generated in 0.14574 seconds (48.90% PHP - 51.10% MySQL) with 10 queries |
