Old 1st October 2008, 12:21 PM   #1
Default Plans to make a 180L cabinet to replace my Berkeleys
Berkeley cabs are ~98L.
Many have said that the Arundel at 180L is a good compromise of WAF and sound. So I have used those measurements.
I though 6mm MDF and 12mm high density fibre board bonded and well braced.
Calcs: as per attachment.
Next for a drawing...
Old 1st October 2008, 12:58 PM   #2
AndrewT is online now AndrewT  Scotland
the Arden is about 200L.
There is a www.paper on building a 300L cab for the 385HPD that reports very good results.
I agree, having used the Berkleys for many years, that the bigger cabinet is a move in the correct direction.
Is the data showing two drivers in a 180L cab? That is only 90L per driver. In my opinion that is too small.
regards Andrew T.
Old 1st October 2008, 02:58 PM   #3
Could not get that link to work.
Just one driver per cabinet.
The Arundel spec is attached / size is attached.
The Berkeleys have 2 ports of 65mm / 120mm deep. Would that be too much in a bigger cabinet. I was thinking 1 x 75mm?
Old 3rd October 2008, 12:36 PM   #4
Any comment on the above question - I will be cutting wood this weekend
eaw cabinet plans Socaflex Multi-Way 25 10th February 2012 09:40 PM
need Manifold 2 x 18 cabinet plans djmarvellous Subwoofers 70 18th March 2011 11:18 PM
AN-E cabinet plans... cypher Multi-Way 14 27th June 2007 08:06 PM
BLH Cabinet plans fin1bxn Full Range 3 27th June 2006 04:03 PM
Page generated in 0.09009 seconds (62.15% PHP - 37.85% MySQL) with 11 queries
