Old 30th September 2008, 10:31 PM   #1
Default A question about painting
I have just finished cutting the wood. I have glued everything together and now I am waiting for it to cure. In the meantime, I began thinking about painting.
I would like to apply a piano black paint. I believe I read somewhere that I should apply 2 layers of black paint and on top of that 12 layers of gloss (lacqure). Is this the way to go?
In addition, should I apply the paint before I cut the holes for the drivers or afterwards?
Thanks for your help
Old 1st October 2008, 02:28 AM   #2
Speakerholic
Cal Weldon's Avatar
This might help
Applying piano black finish help
There are others, do a search
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st October 2008, 03:03 AM   #3
MJL21193's Avatar
Default Re: A question about painting
Definitely cut the holes before you paint. Make the recess (if your drivers are going to ne flush mount) a little bit bigger to allow for the paint thickness.
More than a few good threads here covering everything you need to know. Like Cal said, do a search.
painting flux01 Multi-Way 10 7th July 2006 04:36 PM
Painting question LizardBrain Multi-Way 10 21st April 2006 01:39 AM
Painting heatsinks HenrikKronborg Parts 25 3rd May 2003 11:39 AM
Help!!!! Need Help With Painting! slicemaster101 Subwoofers 10 19th April 2002 08:03 AM
Page generated in 0.81189 seconds (8.82% PHP - 91.18% MySQL) with 11 queries
