Refurbishing a Yamaha NS10M pair - Page 2 - diyAudio
Old 6th October 2008, 01:19 PM   #11
diyAudio Member RIP
You should have practised on a cheap paper driver first.
You now know this, and that the repair is somewhat overkill.
I'm just saying this to help others :
Wetting the area does help, using glue to do this does not.
Tiisue paper is not needed unless there are gaps the PVA will not bridge.
In this case apply the tissue from the back, just enough to bridge.
The minimal amount of diluted glue on the edges is the best.
Do not worry about what the back looks like, get the front right.
Creases you cannot fix, and they rarely cause a problem.
As ever KISS usually works best.
/sreten.
Old 13th October 2008, 11:52 AM   #12
gilwe is offline gilwe  United States
Thanks Sreten,
I actually ended up have a beautiful looking and sounding pair after all...
The fixed membrane seems to work great, and sounds amazing at its own. I do feel that the repaired monitor delivers a tad less of low frequencies (at the 60Hz-80Hz range ?) but I'm not sure the difference has anything to do with the fix and I also hear better midrange on that monitor !
Refurbishing Polk RTA 12 901Fixer Multi-Way 1 14th July 2009 03:24 PM
Build your own Yamaha NS10m studio benjamink18 Multi-Way 11 19th September 2008 07:26 AM
Need Pair of Yamaha S3115H Circuit Boards preacherMDF Multi-Way 0 12th July 2008 04:55 PM
Inherited a pair of Yamaha S3115H (long?) djkib Multi-Way 8 6th June 2008 09:50 PM
FS/FT Yamaha NS1000M's (Pair) LPJones Swap Meet 1 24th March 2008 01:13 PM
Copyright 1999-2017 diyAudio
