Old 27th September 2008, 05:03 PM   #1
Default quandary??
Here's one for you boffins!
overheating output transistor when left hand speaker is hooked up to either L or R amplifier channel, so looks like its maybe a crossover or driver fault...BUT!
swapped over the crossovers, leads, tested ohmage of all three drivers on said speaker there all ok, all same volume, still the amp op trannie gets hot? checked binding posts for continuity and amplifier ground/s
Any ideas?
Old 27th September 2008, 06:05 PM   #2
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Are you using very long speaker leads? There could be some oscillation going on here. Could also be something fishy going on with the speaker that you're unable to see with an ohm-meter.
Impedance quandary fauxpas Tubes / Valves 30 19th November 2007 10:04 PM
Page generated in 0.07695 seconds (60.80% PHP - 39.20% MySQL) with 10 queries
