Reading about ESL systems, i've noticed a point on IM/Doppler distortion - that when one driver is used for all the audio spectrum, these distortions are quite high, and multi-way systems are used to reduce such kind of distortion.
However, I wondered, does the separation really help? May it be so that sound radiation from one driver affects another driver in such a way that it produces IM and/or Doppler distortion? And how much is distortion really reduced that way? |
#2 | |
Sound radiation from nearby sources couldn't possibly cause it unless there were absurd amounts of pressure change to affect the high frequency emitter. |
#3 |
breez
I understand that, but, I am talking about air affecting air, not the emitter itself. The emitter isn't of course likely to be affected by air pressure change(but in case of ESL, it is more probable), but the air it emits to, is affected, causing probable changes in level of air loading. |
#4 |
Remember, though, the displacement of large panel transducers is still quite small. As a practical matter, ESLs have rather low IM.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 | ||
For example, wavelength at 10KHz is 34.4 mm. For any appreciable effects to occur we need at least several millimeters of displacement. For a large panel this means SPL in the range 110dB+ @ 20Hz. |
| Doppler distortion in fullrange drivers | sharpi31 | Full Range | 8 | 24th May 2007 12:24 PM |
| Sound Technology 1700B Distortion Measurement Systems for sale | nwaero | Swap Meet | 0 | 15th December 2006 07:09 AM |
| Multi purpose multi channel gainclone PCB: Team project - group buy | rick57 | Chip Amps | 14 | 29th March 2003 05:54 PM |
| Doppler encode/decode | Bill F. | Multi-Way | 3 | 8th January 2002 10:22 PM |
| Page generated in 0.12196 seconds (60.73% PHP - 39.27% MySQL) with 10 queries |
