I am looking at making best loudspeaker I can afford in $1600-$1700 range (excluding the boxes). ZRT2.5 seems to be the best bet at the moment but I would prefer to have it in a TL enclosure. ATR2.5 seemed ideal but it is way above my budget due to the expensive drivers used, and I am not sure if they are so much better compared to the onces used by Zaph. I also have a fancy for Ribbon tweeters, but not having heard them I don't know how much that would help either. I love to do DIY, but I am a beginner in loudspeakers area. I would want to build one really nice set of loudspeaker and then move on to my other DIY plans... Can someone highlight any proven projects which would meet my requirements, or help me with ZRT2.5 in TL enclosure & crossover? |
#2 |
frugal-phile(tm)
What is a ZRT 2.5? Link?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Soft Dome |
#4 |
ST7677 -
Since you are a beginner and you want to get the speakers built and "move on" as you say, modifying an existing design (i.e., doing in in a TL) rather complicates that goal. Stick with an existing design and build it as is. Of course Planet10 may have some input on this regarding the TL. Also I'm a bit confused when you say you have a "fancy" for ribbon tweeters yet you've never heard one - you should approach speaker building from a point of neutrality and not favor any particular type of driver (or design) you're not familiar with. The stuff Zaph does is good - if the ZRT is too expensive look at his other designs, such as the ZDT3.5, SR71, BAMTM, ZD5, SEAS L18. Hard to go wrong here. The ScanSpeak drivers in the ZRT are arguably the best available, but there are cheaper alternatives that will give very good performance and high value. Consider the designs here also: http://www.geocities.com/woove99/Spkrbldg/
Soft Dome |
#5 |
I agree, I would not want to go away from the published design without anyone's help / guidance in doing the same.
So are there any 2.5 way projects with good drivers in TL enclosure with excellent reputation? |
#6 |
I've heard the Event, and it sounded great. Bass was very strong and deep.
http://www.audiocomponents.nl/speake...lassic_eng.htm Would other drivers (Lower VAS, Higher Fs) work well in the Event enclosure? |
#7 |
I found Seas Thor here
And it's kit here at $1365 How would this compare against ZRT 2.5 And it's kit at Madisound for $1400 Seas is a 2001 design in a TL enclosure where as ZRT is 2008 design in Sealed/vented enclosure. I guess both use excellent drivers (Seas vs ScanSpeak) in 2.5 way configuration... |
#8 | ||
frugal-phile(tm)
Read these (the 1st thread is LOOONNNGGG. Clarity on Seas Thor Kit Some Thor models to mull over Curved Small Thor Build Here's another Thor (Small) Short Thor Internal Layout Joe D'Appolito's THOR (Seas) Madisound SEAS Thor Kit Thor stories dave
#9 |
I went through most of these threads and looks like people have got mixed results from Thor design. Also there is lot of confusion regarding which one is the right Thor design, both Cabinate and Crossover are being questioned. I guess it would be safe to stay with ZRT 2.5.
Are there any reviews of ZRT 2.5? Search shows only 3 threads with ZRT on this forum and none has a detailed review... Has anyone done this project? |
#10 |
"Danish School"? No. Zaph School.
Soft Dome |
| topology similar to BCA | 81bas | Class D | 3 | 22nd July 2009 09:08 PM |
| I'm Looking for this Similar Schematic ! | calico88 | Tubes / Valves | 7 | 21st April 2008 03:48 AM |
| similar to SKA | djk | Solid State | 6 | 7th June 2007 03:28 PM |
| looking for similar FET | Ahmad_tbp | Solid State | 5 | 6th May 2006 09:26 PM |
| Similar DC/DC coverters? | eeka chu | Digital Source | 1 | 20th April 2004 08:49 AM |
| Page generated in 0.13835 seconds (72.92% PHP - 27.08% MySQL) with 10 queries |
