#651 |
You're just trying to avoid that I show that all you said about "active absorption" is complete nonsense. Sorry, it's the truth.
#652 | |
Now why would I do that, for any subject? Have you ever seen drivers (in other loudspeakers/subs) that were in the same room but were not "on" and were moving? If not, I'm sure you would say that it was impossible.
perspective is everything |
#653 | |
Hi Bill I guess you are referring to that paper of John Kreskovsky : http://www.musicanddesign.com/PowerMatching.html Though OT, I guess Johns suggestion is to use a combination of a monopole *and* a dipole "Clearly, somewhere between the cardioid and the monopole there exists a situation where the relative strength of the monopole and dipole are such that DF = 1.5 can be obtained on axis. " The solution I find working fine is to use two dipole woofer at 90° which sum to the desired 45° ![]() I use the "split power approach" actually intended / implemented to reduce excursion - to gently turn the axis from 0 (at roughly 300Hz) to 45deg around 100Hz and below – as a positive side effect. I found that to be an even more elegant solution. As for your question – no clue. But it works – most important for me. Michael
Audio and Loudspeaker Design Guidelines |
#654 | |
#655 | |
This whole DBA discussion is only academic because in a real-world situation there is no room that has perfect symmetry and rigid walls that allow for the wave to stay planar while it's travelling. |
#656 |
Michael,
Yes that is the paper. I built John K's NaO that has an U-frame (sub) woofer. I am far from as advanced as you guys. Dipole or monopole, the biggest problem I have is room modes in my small room with rather odd dimensions (2.5m height x 5.1m width x 6.3m long). My basic measurements indicates that it is ruler flat nearfield but in farfield a 6dB peak at 80Hz and a broadband 6dB dip between 200Hz - 500Hz (which is a mystery). Although base directivity may arguably reduce room modes, I think I will adopt Dr. Gedlee's multiple monopole sub approach which appears to have been proven to work. So my next pair of speakers have a removable back on the woofers, and I will first try monopole, and if not successful, remove the back and try cardiod (a lot more complicated measurements and EQ). Regards, Bill |
#657 | |
We have a highly regarded member (an EE) of our local audio society who not too long ago was still running mono. I didn't know him in his mono years! He does design speakers and dislikes most; his own do image quite well and he says he worked hard to get it including a dedicated room in his home. He also designed and fabricated a turntable nearly from scratch with some impressive and unique features. I sometimes think that a stereo system that does not produce a good center image is certainly a step backwards. Pete B. |
| Page generated in 0.10642 seconds (79.96% PHP - 20.04% MySQL) with 11 queries |
