Beyond the Linkwitz ASP - Page 3 - diyAudio
Old 3rd October 2008, 03:26 AM   #21
cuibono is offline cuibono  United States
cuibono's Avatar
Hmm, the XO's don't sum flat. Bad news. Must be an inappropriate Q.
For a given slope, there must be an ideal Q (like 12dB/oct is .5, 24dB/oct is dual .71). What Q gives a flat response for 24dB/oct with only one filter?
There must be active XO filters using a single opamp that can do more than 12dB/octave...
Old 3rd October 2008, 11:10 AM   #22
infinia is offline infinia  United States
infinia's Avatar
Hi
Q is only defined for a 2nd order polynominal expression.
LR filters are formed by cascading of 2nd order Sallen-Key filters, and are of even order LR2,LR4,L6, etc each stage with it's own Q. Luckily, crossover filters of higher order than LR4 are probably not useful, because of an increasing peak in group delay around f0.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 3rd October 2008, 03:43 PM   #23
cuibono's Avatar
But does a LR XO filter have to be cascaded 2nd order filters? I don't see why, and no one has come out and said so, yet...
I'll keep messing with it today...
Old 12th November 2008, 05:35 PM   #24
cuibono's Avatar
For the record...
At burning amp this october, I had the chance to talk with Mr. Linkwitz. He said he could not recall ever seeing a fourth order filter around one opamp. So it sounds like it isn't a trivial task - and probably doesn't have much to gain. I am going to continue developing a multi-channel line level ASP for my three (or four) way speakers, I'll just have to accept a couple extra opamps.
Old 12th November 2008, 07:30 PM   #25
That is right. He is a great master in electronic filters.
But that is only referring to electronic filters.
A single opamp usually gives a second order filter (Third order is fine but you will have some insertion loss which may or may not be an issue). If your driver has a 1st order roll-off, dipole roll-off is also 6dB/oct, so using a single opamp with second order can achieve 4th order. Your second order usually need to have a high Q in order to come up with a LR4.
Bill
Mr. Linkwitz' presentation (AES) gainphile Multi-Way 8 8th May 2008 11:29 PM
Linkwitz sub heinz1964 Subwoofers 7 1st October 2007 07:09 PM
Linkwitz Orion x-over pcb's 2 for 1. Tristanc1 Swap Meet 4 26th March 2007 08:01 PM
Linkwitz Transform PCB? diydave Parts 2 1st September 2005 12:05 AM
Copyright 1999-2017 diyAudio
