Old 23rd September 2008, 04:23 AM   #1
gainphile's Avatar
Default Correcting 'valleys' in FR
I know that to correct frequency response peaks notch filters are used. My question: is there a "reverse notch" to correct valleys, perhaps an active one ?
http://gainphile.blogspot.com
Old 23rd September 2008, 05:34 AM   #2
boggy is offline boggy  Serbia
Send a message via Skype™ to boggy
Default Re: Correcting 'valleys' in FR
Hi gainphile, one possible way to build an active "reverse notch", you can find on attached schematic.
Hope this helps!
Old 23rd September 2008, 05:39 AM   #3
gainphile's Avatar
Thanks Boggy,
I could not see the attachment. Did you miss it ?
Old 23rd September 2008, 06:08 AM   #4
ttan98 is offline ttan98  Australia
Gainphile,
I notice you using the Alpha 15" driver as the OB bass driver.
These fairly large drivers sitting on top of your table seems a little daunting for me maybe not so much for you.
Cheers on a successful implementation.
Old 23rd September 2008, 06:30 AM   #5
frugal-phile(tm)
planet10's Avatar
Thanks Boggy,
It was there... attachments are moderated in a different queue than messages, and if a mod is in a hurry he can forget to moderate the attachments attached to a post, in which case the message shows up & the picture doesn't.
dave
PS: you should be able to see it now.
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd September 2008, 12:32 PM   #6
gainphile's Avatar
Originally posted by ttan98
Gainphile,
They don't seem to big after awhile . From many experiments only dipoles can live in my small study.
dave
Yes. Seen it now ... thanks heaps I'm studying this circuit.
Old 23rd September 2008, 09:54 PM   #7
David Gatti's Avatar
The passive way would be to design an enclosure shape where diffraction peaks occur at those valleys.
Old 23rd September 2008, 11:46 PM   #8
IMHO, this can be useable, if you build a loudspeaker which measurements (only) are "flat"....
But, if you have a some "drop" in speaker sensitivity in relatively small frequency range (one octave, for ex.), caused strictly by electro-acoustical parameters (impedance, ... ), not only acoustical (diffraction,... etc.), ... this problems cannot be cured with each other... Electrical problems must be treated with electrical circuits (filters, generally...)... acoustical problems... with better acoustical construction... (dampening, shaping, etc.)
Old 24th September 2008, 12:21 AM   #9
holdent is offline holdent  Canada
gainphile:
I don't think correcting the "valleys" or nulls is a good idea. Some nulls can be 10 dB, 20dB, or more. Providing equalization for nulls in the bass region can require substantial power and may quickly overload your driver. I think a better approach would be as David Gatti suggests -- change your enclosure choice and knock down the response peaks as necessary.
...Or simply put up with the peaks. Some enclosures, such as the Nagaoka family of TL/horn hybrids at the Frugal-Horn website, have a number of nulls inherent in their design and still get excellent DIYer reviews.
Old 24th September 2008, 12:58 AM   #10
martinv is offline martinv  New Zealand
martinv's Avatar
Default parametric equaliser
Hi gainphile,
Some time ago I played around with using a parametric equaliser in order to tame peaks and valleys. For those who don't know, a parametric equaliser typically has three controls; one for selecting the centre frequency, another for setting the boost/cut level, and a third for adjusting the width of the frequency range being affected. Kind of like a graphic equaliser with just one slider, but you can adjust the frequency the slider takes effect at as well as the 'broadness' of the range being affected. Maybe a circuit for such a device would be worth looking for. I think Silicon Chip recently had a sub-woofer filter that incorporated such a design. Let me know if you need to know the issue and I'll have a search.
OK, that's your question answered... Now my advice - don't do it. :-)
As opposed to peaks, it's popular belief that valleys are nowhere near as noticeable.
Here's another thought - what is causing the valley? You may be fighting a losing battle if it's a room interaction problem.
Yet another thought - this valley - does it occur at every listening point? (I know that's difficult/impossible to measure) If not, you might be fixing up one point at the expense of other listening points. A bit like the experiment I did to decide whether to offset a driver - www.gadgets.co.nz/mjv/loudspeakers/exp01.shtml
Anyway happy open baffle building.
-M
Xenaphobia - Fear of being beaten to a pulp by a leather clad New Zealand woman.
Impendace correcting for drivers Nisbeth Digital Source 0 13th March 2001 06:43 PM
Page generated in 0.17467 seconds (65.42% PHP - 34.58% MySQL) with 11 queries
