Big speakers in none ported enclosures.
Old 22nd September 2008, 11:55 PM   #1
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default Big speakers in none ported enclosures.
I have a Fane Colossus 18 inch 600 WRMS speaker.
It is recommended that I use a ported enclosure.
As I need to move the speaker around then I need to keep it as small as possible. This is fine but precludes the use of a port.
Will I do any damage to my speaker using a none ported enclosure ? The only air leakage into the enclosure will be through two quarter inch jack sockets on the side of the enclosure.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 23rd September 2008, 12:04 AM   #2
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
no it won't damage your speaker but you won't get much bass out of it (assuming the jack sockets are plugged when you use it)
The back pressure in the cabinet will prevent the cone from moving enough to develop low frequencies.
...but I always thought that, given a particular speaker, the ported cabinet would always be smaller than the sealed cabinet for optimum LF response??
Old 23rd September 2008, 12:08 AM   #3
There is no room at the front around the speaker for a port.
I suppose I could put one on the back of the box if it was kept simple.
Would a simple hole do the job or would it need a pipe ?
Old 23rd September 2008, 12:15 AM   #4
BHTX is offline BHTX  United States
BHTX's Avatar
Rarely. Just depends on the driver. A Qts well above .40 often requires a large sealed cab. Very low Qts drivers (like under .2) often require tiny vented boxes, but those don't usually provide much low freq response anyway.
In the case of this Colossus 18, I'm guessing low freq response will be VERY limited in a sealed enclosure, and that boosting the low freq way up via EQ to overcome that probably wouldn't be a good idea for anything other than a personal application in a person's home, given that Xmax is probably limited to 5-10mm. However, an optimum vented cabinet for it will most likely be fairly large. A sealed cab would probably be very small, but not have any low freq output to speak of.. at least not without a lot of EQ, which will hinder max output substantially.
Old 23rd September 2008, 12:20 AM   #5
I want to use the speaker in a mobile disco environment so it needs to be as loud as possible.
Would a simple opening on the rear of the box allow in enough air to get sufficient bass ? Or would this pollute the sound from the front ?
Old 23rd September 2008, 12:22 AM   #6
BHTX's Avatar
Doesn't work that way.
First of all, you need to figure out which Colossus 18 you have, as there are currently several (4 I think?), and there might have been even more in the past. Check this link here: http://www.fane-acoustics.com/proseries.asp
Once you figure out which one it is, you need to download the PDF and enter the TS specs in WinISD Pro or something similar to simulate an optimum enclosure.
If you're trying to put it in some sealed enclosure of an unknown size, there's a small chance it might work OK by selecting the right diameter and length of PVC pipe (or whatever) and making a corresponding hole in the cabinet. Chances are slim though. If it's an old sealed cab for a single 18", it's probably too small.
First things first.. figure out which Colossus 18 it is and model it.
Old 23rd September 2008, 12:32 AM   #7
I downloaded Win ISD.
I need a 4 inch diameter hole with a 4.16 inch pipe to vent the enclosure to get a decent response.
Thanks for the help, Nigel
Big speakers in none ported enclosures.Hide this!Advertise here!
advice on micro speakers and enclosures geom_tol Car Audio 12 15th June 2007 12:19 PM
New enclosures for Logitech speakers JWFokker Multi-Way 7 21st March 2005 12:17 PM
integrating subwoofers with ported main speakers keyser Multi-Way 11 15th March 2005 11:00 PM
Membrane to limit "unloading" in ported-type enclosures? Datoyminaytah Multi-Way 6 18th August 2004 05:36 PM
