Hi
I am finishing a line array with Fountek Neopro5i's. They have binding posts internally so they look like they are designed for a banana, spade or bare wire non-soldered connection inside the speaker. Just like you would wire externally. Do you think there will be any problems just cranking down a bare wire connection inside the speaker? I don't want it to come loose. The mid ranges are Seas mag cones. I plan on using the disconnects there unsoldered also. I can't imagine those disconnect "sleeves" coming loose. What do you think? |
#2 |
Tin the bare wire with solder, form a round shape and clamp with the post. |
#3 |
If you're real paranoid, put some locktite 271 on the threads of the binding post.
The power of Science compels you! |
| internal speaker connections - newbie question | speakerbug | Parts | 6 | 29th February 2008 03:12 PM |
| Ribbon Internal Connections | Victoria | Multi-Way | 4 | 8th February 2006 04:05 PM |
| HELP with connections | Tony.ca | Multi-Way | 7 | 23rd May 2005 11:56 PM |
| PYE HFA 12 (AKA pro-lab 100) internal connections | steve_v | Multi-Way | 0 | 10th December 2004 06:25 AM |
| Page generated in 0.07850 seconds (59.14% PHP - 40.86% MySQL) with 10 queries |
