Searching on the web, the specified upper limit of frequency response of this DVC 8 inch woofer is mostly given as 800 Hz. In MCM's 2009 catalog, the upper limit is given as 8 kHz. Has anyone tested whether or not 800 Hz is correct?
Unfortunately at this time I can only make nearfield SPL measurements, and a quick answer to this would be helpful. As I already have four of this woofer, I'd like to make use of them, but they should have an upper limit of at least 2 kHz for what I want to do with them. 800 Hz seems a bit low for a 8 inch woofer, while 8 kHz would seem to be too high. Alternatively I would want to locate some other DVC 8 inch or 10 inch woofer with Qts equal to about 0.2~ 0.3 with the voice coils connected in parallel , and fs not any higher than about 30 Hz. Any help is appreciated. Regards, Pete |
| Hexagon Pioneer B20FU20 Enclosure | John L | Full Range | 323 | 4th May 2012 06:02 PM |
| FYI Pioneer B20FU20-51FW | jackfish | Full Range | 2 | 19th April 2009 09:38 AM |
| Pioneer B20FU20-51FW 8 TL? | aznboi3644 | Full Range | 15 | 18th December 2007 10:01 AM |
| PIONEER B20FU20 or GOLDWOOD GW-8003/8 | sandman | Full Range | 13 | 18th November 2006 07:27 AM |
| pioneer b20fu20-51fw | injunandrew | Full Range | 11 | 18th April 2005 09:30 PM |
| Page generated in 0.06139 seconds (68.74% PHP - 31.26% MySQL) with 10 queries |
