Old 15th September 2008, 11:04 AM   #1
BL21DE3 is offline BL21DE3  Scotland
BL21DE3's Avatar
Question Using solid wall as back of speaker enclosure?
Hi Folks,
Needing to satisfy WAF I've built a variant of these speakers http://www.visaton.com/en/bauvorschl...anleitung.html using 12mm birch ply. My question however is would it be possible to modify them so that the rear wall of the enclosure was actually the solid internal wall on which the speaker would be mounted? Obviously I'd retain the internal stuffing and bracing for the baffle. I did a search on here but didn't have any luck turning up any advice/info on such an approach/design.
Any advice/suggestions are appreciated.
Ewan
Old 15th September 2008, 12:52 PM   #2
You'd need to ensure that the wall/cabinet junction was sealed, might make it a bit hard to move them when she re-decorates...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 15th September 2008, 01:19 PM   #3
BL21DE3's Avatar
Thanks for the reply. Looks like it's probably safer to go with the cabinet 'as is' it'll make it easier to move when it's time to re-decorate
Old 15th September 2008, 07:00 PM   #4
I assume these speaker are being mounted IN a wall or on a wall, and that begs the question...is it really solid?
Yes, I'm sure it is one continuous unbroken expanse of material, and in that sense is solid.
But is it solid in the sense of absolutely ridged, immobile and unshakable. If it is standard wallboard or sheet rock, then the answer to 'ridged, immobile. and unshakable' is NO, it is not.
Steve/bluewizard
Old 15th September 2008, 10:41 PM   #5
BL21DE3's Avatar
Hi Steve,
Thanks for the reply. The wall I was intending to mount them on is the solid partition wall between my house and my neighbours, which is composed of concrete blocks covered with a skin of plaster. I know this from having drilled into the wall previously and also seeing the unfinished surface of these walls in the loft.
Ewan
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
Open baffle VERY close to back wall? Fast1one Multi-Way 6 4th April 2009 07:01 PM
Uneven distance from back wall? Lewis Moon Multi-Way 0 5th October 2008 10:12 PM
in-wall/on-wall speaker? (axiom w-22 clone?) Scott_fx Multi-Way 0 22nd February 2007 02:08 AM
Distance of port to back wall? mitch808 Multi-Way 9 10th June 2004 07:51 PM
Page generated in 0.06876 seconds (78.96% PHP - 21.04% MySQL) with 10 queries
