What does the 47ohm in series with the 1mh on the woofer (R2011) do in this design?
http://www.troelsgravesen.dk/AT-R.htm |
#2 |
It's helping the inductor to shape the woofer response properly. Somewhat similar to how a "proper" BSC circuit would function, although here Troels is using it how any designer would, to help shape the response. The basic idea is that he can use a bigger inductor to get the "knee" of the transfer function low while not rolling off the upper response too much.
EDIT: BTW it's in parallel, not series. Taking some inspiration for your commercial design for the upcoming RMAF? |
#3 | |
I have my network pretty much finalized, maybe a tiny tweak or two now that it's soldered instead of clip-leaded together. But yea, I saw that this evening and was curious. My AT driver is a bit different than his, and he gets a bit more rising response than I do so ... but we do have very similar networks, 2nd order with a notch for the rising response. That 47ohm works since he's crossing over a hair higher than I am. Thanks again for the reply. |
#4 |
| Troels' design has been completed (JA8008/TW034 DTQWT) | tf1216 | Multi-Way | 29 | 8th November 2011 09:04 AM |
| Need Quick Help if Possible (Question And Design) | Rounder | Multi-Way | 37 | 12th January 2006 11:25 AM |
| Quick help for TL design | theChris | Multi-Way | 14 | 14th March 2005 06:19 PM |
| A quick design of a 6 ch. LM 4781 amp | microJean | Chip Amps | 4 | 19th August 2004 10:32 AM |
| Page generated in 0.10234 seconds (73.64% PHP - 26.36% MySQL) with 10 queries |
