I notice on high volumes (with LP less than ~60hz) that the woofers make a noise because they reach their xmax limit.
Does it mean that is too much for them? The scan do have low fs and can get lower bass but I guess it's only for love levels? |
#2 |
Did it Himself
Fs is no indication of how well a speaker can handle high SPL. Yes it is too much for them. You may be able to improve matters by box design.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
Thanks.
I wrote about the fs as some indication of the 15w reaching low frequencies (rather than high SPL). So I guess 5.25" shouldn't be used to handle high spl (in home/car terms) with frequencies lower than 60-70hz? The only experience I had with them before was with a closed box MTM center. The amp doesn't send lower bass to this channel so I notice any problems. In the above matter I used them in a car on the rear walls instead of the original 6x9 . In this case the only control I had was the acoustastuff filling and wall covers. Quote:
#4 |
Did it Himself
Ah it's a bit clearer now
#5 |
Their specs are so close to the 7" revs. That's what so confusing.
I do have the 7" in a transmission line (self design for a friend) and I don't recall xmax problem there. Such a small difference in size, such a big difference in drivers behaviour ?! I wonder how you handle it. Do you HP the woofer (and LP) or just limit the power going in although you can get higher mid SPL? |
#6 |
The 15W will exceed it's excursion limits at 70 Hz with 40 watts in a sealed or vented enclosure. About 20 watts will exceed xmax below 50 Hz.
In comparison the 18w will will exceed it's excursion limits at 64 Hz. with 40 watts in a sealed or vented enclosure. About 20 watts will exceed xmax below 40 Hz. I really like the revelator drivers but I would be very willing to trade some of the low frequency extension for the ability to play louder without exceeding xmax like the 18w8545 Regards, Dennis |
#7 |
In that case 2.5 way using a 8545 for bass only (below 70hz) is better than using the rev for bass below 70hz.
I always suspected that but never checked it out. I do have 8545 in my main speakers for lower bass (vented box). I think their bass is awsome, but sometimes they do get to their xmax on very low frequencies (20-30) at high SPL. |
| Wrms, FS or xmax | onform | Subwoofers | 4 | 24th June 2008 07:09 PM |
| Xmax | dallaire | Multi-Way | 2 | 25th December 2007 09:47 AM |
| Xmax Question | jwatts | Multi-Way | 13 | 5th February 2005 12:11 AM |
| Xmax | mik | Subwoofers | 12 | 1st December 2004 04:39 AM |
| Reaching for the "highs" in a speaker | WildWest | Multi-Way | 2 | 23rd May 2001 09:00 PM |
| Page generated in 0.08685 seconds (86.17% PHP - 13.83% MySQL) with 10 queries |
