Old 13th September 2008, 08:22 PM   #1
Default Need advise on speaker build
Looking for advice? I have a pair of IPL acoustic ribbons which are now a bit to toppy since amp upgrade. I have brought down the value of the tweeter cap which has helped a lot, but still grates a bit. I now want to do another speaker build. Looking for medium sized, 2 way floor standing which is not forward in the upper frequencies and in the 87 or up wards db. I thought about doing the Proac 2.5 clone, but it seems this speaker can bit a bit revealing and also not that sensitive. I want to go a bit higher end then the IPL, and have a budget of around £750. Can anybody recommend a build? I do not need to go full kit as I can get panels cut to size and holes made for drives; I have built from scratch before.
Old 15th September 2008, 12:42 AM   #2
some good options here:
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 15th September 2008, 01:59 AM   #3
tinitus is online now tinitus  Europe
Quote from his site
To my ears, this is the best speaker I've ever made - and the biggest!
http://www.troelsgravesen.dk/JA8008_DTQWT.htm
Old 15th September 2008, 09:38 AM   #4
Thanks should be some thing their
Old 15th September 2008, 10:24 AM   #5
sreten is online now sreten  United Kingdom
Regarding the "toppiness" try a L-pad arrangement.
Sensitive ? try : http://www.zaphaudio.com/Waveguidetmm.html
/sreten.
edit : Monacor do a waveguide not available in the States.
advise on 2nd build Mindcrime Multi-Way 2 12th January 2009 12:58 PM
Speaker guy looking for a CD player kit. Advise? R-Carpenter Digital Source 2 16th April 2008 12:59 AM
speaker project, need a little advise... punkrocker5817 Multi-Way 21 4th June 2007 06:04 AM
The HDS-XLS speaker KIT from d-s-t.com.au and WES componets - Need some advise JoeyJoJo Full Range 1 25th May 2005 05:13 PM
Page generated in 0.08976 seconds (72.77% PHP - 27.23% MySQL) with 10 queries
