#11 |
When you talk about high power what voltage & amperage are you talking about??
I was under the impression that crimping was only done because it is almost impossible to solder anything over 6mm*2 Unless you have access to hydraulic crimpers is it possible to do a good crimping job?? I use solder to ensure a pre-crimped connection can't vibrate off the tag and some rally engineers I have known do the same thing ( actually that's where I first encountered the practice )
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#12 | |
The problem is multi-fold. 1. Most crimp connections are designed to place a certain amount of pressure, over a certain amount of area, if you solder before crimping the wire can't spread out correctly and the crimp won't have the correct shape and the correct clamping force. 2. When soldering after a crimp, the solder travels unevenly up the strands of the wire, creating uneven application of force if the wire is flexed at the crimp/solder point. Individual strands will break before he others, and the failure point is inevitably the solder joint end...I've seen this in person, in the project I first did as an engineer. I've seen very large cables crimped, and I've seen crimpers that look more like bolt cutters, with 3' handles. Proper crimping pressure is what's needed.... One MIL-SPEC project I worked on required that every crimp was pull tested before inserting into the system. Dang that was a pain in the gluteous maximus. The paperwork alone was a nightmare. Scott |
#13 | |
But the technology should work for low power as well. That's where most of the probs I've seen are at the spade end not the crimp itself. If you solder just the wires, you can use less heat at the tweeter terminals and eliminate one connection out of two.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#14 |
To prevent/contain heat spread and damage use mini alligator clips and hemostats as heatsinks.
With good solder & pre-cleaned/ tinned surfaces, I haven't had a cold joint problem or heat damage. ( I also like to use a liquid flux in a syringe applicator ). I strongly prefer solder connections ( unless the driver comes with good spring connectors ). In subdued lighting I have seen "microarching" between 1/4" spade lugs and tabs, with pitting on the metal contact surface. |
#15 |
Hmmm........ So you guys think that soldering a crimped spade is not a good idea? It works well for me.
Certainly I've done many 1000s of crimp connections - mostly BNC or F connectors on coax - and they worked fine. But with rough treatment they often break. (Not saying they'd get rough treatment in a speaker). The typical crimps I've seen on small gauge spades has not impressed me. That's why I solder, too. But hey, I'm willing to learn a better way. FWIW, I don't solder to drivers.
Take the Speaker Voltage Test! |
| Source for .110", 26-20AWG Female Spade Connectors (for speakers & such) | EchoWars | Parts | 0 | 4th December 2008 05:25 AM |
| Needed Heavy Duty Spade Terminal Connectors | speedemon | Parts | 2 | 13th February 2007 12:13 AM |
| banana or spade for 12-ga wire | Alex Barnett | Parts | 4 | 29th December 2006 03:48 AM |
| Big spade connectors? | gfinlayson | Multi-Way | 6 | 1st February 2006 01:13 PM |
| Lug or spade - that's the question | peranders | Parts | 12 | 11th January 2004 04:23 AM |
| Page generated in 0.10344 seconds (74.36% PHP - 25.64% MySQL) with 10 queries |
