Big sound from little speakers? - Page 4 - diyAudio
Old 13th September 2008, 12:56 PM   #31
Originally posted by ShinOBIWAN
I have no experience of the Bose being discussed but as far as small speakers go these are the best I've heard:
http://www.genelec-ht.com/products/active-2-way/6020a/
They're frighteningly good for something that you can get a grip on with one hand but quite a bit more expensive than the Bose though.
I thought about DIYing a small speaker for surrounds but TBH I'm grabbing a pair of those. The benefits of DIY just don't weigh in this case.
Genelecs are ridiculous - ridiculously good. A couple of us guys built a MAME arcade cabinet with a PC inside. We were missing a speaker so we borrowed a couple of Genelec monitors. They were so punchy and dynamic that we couldn't help but laugh out loud when they were blasting the Golden Axe sounds. Gotta hear those tiny ones ...
Old 22nd November 2008, 03:03 PM   #32
Send a message via AIM to omarmipi Send a message via Yahoo to omarmipi
Originally posted by crazyhub
Same need, my next speaker will be such a small thing with big sound; I feel I will not get what I want if I use an extended range 4-5" driver, even not a classical mid-woofer + tweeter kind of combo; I guess a woofer/subwoofer going low in a small VB + 2" mid-tweeter will work the best.
I choosed a driver, kind of subwoofer working in 2.7 liters f-3 = 80hz:
http://www.tb-speaker.com/detail/1208_03/w5-876sd.htm
The mid-tweeter will be this one:
http://www.tymphany.com/files/products/pdf/830970.pdf
loaded in 0.2 liter:
Could have been one of the 2" TB...
Baffle width approx 15cm so a BS f-3 of approx 766Hz which will also be the x-over cutoff fr; simple 1st order filter + eventually RLC// to the bass driver if needed.
Brilliant! I've been thinking of using the Tang Band W5-876SD together with the W2-852SF for some time now. Please share more of your ideas when you get the chance.
Old 22nd November 2008, 11:11 PM   #33
PB2 is offline PB2  United States
PB2's Avatar
Did you consider these:
http://www.parts-express.com/pe/show...number=264-872
I've not tried them, but I have a pair of these that I'm just starting to evaluate:
http://www.parts-express.com/pe/show...number=264-874
Giving them enough baffle step will make them sound "big", however obviously then you run out of Xmax fast. A Qtc as high as 1 or more can also help since the peaking is similar to baffle step and the faster rolloff below helps reject LF that might otherwise waste available excursion.
Smooth, clean performance beyond Xmax is an important consideration.
It's about VD, how much air the driver can move.
Pete B.
Old 23rd November 2008, 02:56 AM   #34
MCPete is offline MCPete  United States
Default small speaker with good bass
Anonymous 1,
You might try what I developed in 2006,
http://www.sound.westhost.com/articles/pikku9.htm
Using a 4 inch woofer, this design requres a closed box of internal volume of about 800 cu. inches.
There is a GREAT sacrifice of sensitivity in this design to enable a f3 of 60 HZ.
If you are interested, I have one pair of the same woofer and tweeter of my original design.
-Pete
No sound from my speakers Artville Everything Else 2 10th April 2009 09:42 PM
No sound on speakers...Need Help .... javinramos Car Audio 3 11th January 2006 03:22 AM
3-Way speakers sound very bad Elefante Car Audio 1 14th August 2004 09:35 AM
headphones that sound like speakers Xray Everything Else 6 14th October 2003 01:13 PM
New speakers sound muffled tim_rule Multi-Way 6 9th September 2003 08:51 AM
Copyright ©1999-2017 diyAudio
