Old 11th September 2008, 10:20 PM   #1
Default 3in midrange buyout
they are advertised to play up to 3khz.
with 0.09 mH inductance they should play much higher.
has anyone measured these drives?
I was thinking to get about 60 of them for line array.
http://www.partsexpress.com/pe/pshow...number=289-084
Old 11th September 2008, 10:53 PM   #2
Andersonix's Avatar
Might be interesting in an open baffle line array with that 0.53 Qts? But 60x$3 is a pricey experiment, and with PE being over-optimistic, 3kHz is probably right. Definitely a visual statement, though (and a chance to tweak with EQ and xover). Get 10 tiny tweeters to go along with your PE order....
Old 17th September 2008, 01:16 AM   #3
got a pair to test. here is frequency response, taken on ~11x17 baffle, 2in mic distance. not bad sounding woofers, my only complain is that pole piece and/or frame are not vented.
Old 17th September 2008, 05:00 AM   #4
planet10's Avatar
I would be complaining if they had vented pole pieces.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th September 2008, 02:48 PM   #5
why? what is downside of vented pole? I'd imagine vent may create unwanted air turbulence...
There are venting holes in cone under dust cap, I had to put paper tape on them. Yes, I already removed dustcaps (measurements depict unmodified driver).
Old 17th September 2008, 06:52 PM   #6
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
a 3/4" voice coil and .020 inch X-max is why. there's not really much air movement, let alone enough to warrant "venting" it.
Old 17th September 2008, 10:34 PM   #7
planet10's Avatar
vented pole pieces are noisy and will have a very specific resonance. The air trapped under the dustcap is bad enuff without adding insult to injury. Not so bad in a sub where there is a seriously opaque dustcap and the oil can resonance should be way above the pass band, but in a mid?
dave
Old 18th September 2008, 03:07 AM   #8
Is it possible to add a phase plug to a driver with a vented pole piece? Would it not cover up the vent? If it did, what would be the result? Of course, the frequencies largely affected by the trapped air under a dust cap is probably dependent on the size of the dust cap etc.. but what area of the frequency range is it usually for say.. a 6.5", 8", 10", and 12" mid woofer with average size corresponding dustcaps?
I've been thinking about this a lot lately, as my buyout Eminence Delta Pro 12's sound to ME like.. big plastic cups.. if that makes any sense. As volume levels increase, it becomes more and more apparent. Just for the record, I've only played them by themselves, both free-air and in sealed boxes. Anyway, I'm guessing it's a combination of the kapton former, dustcap, and vented pole piece.. but I'm wondering which of those is contributing to it the most. If I can figure out something to improve upon the negative characteristics of these drivers, I'd most likely end up modifying them a bit.. if only I knew where to start, and the best ways to go about doing it.
Old 18th September 2008, 03:33 AM   #9
planet10's Avatar
An easy experiment would be to stuff the pole vent with some damping material (not a good long term solution as fibres might migrate into the gap).
A phase plug over the vent hole would seal it if secured appropriately, get rid of the vent's oil can resonance, the voice coil's oil can, and improve HF response.
dave
Old 18th September 2008, 02:41 PM   #10
ordered 40 pairs of these instead http://www.partsexpress.com/pe/showd...number=309-160
my plan is to tear them apart and glue drivers by magnets together(bipole), 20x20, no enclosure, just mounting rails.
Need curve on Vifa PE buyout please Bill Fitzpatrick Multi-Way 8 5th March 2008 09:06 PM
Buyout Plate Amp LightwaveDude Subwoofers 47 15th June 2006 03:06 PM
HELP! Need a PE 299-752 3" Sammi Buyout Lance Multi-Way 7 17th May 2006 11:26 AM
PE 299-145 buyout 5.25 PPcone MarkMcK Multi-Way 46 30th June 2005 02:06 PM
buyout lighting audio P3.12.4's -- who got 'em? mista2 Car Audio 2 4th November 2004 07:42 AM
Page generated in 0.10820 seconds (80.74% PHP - 19.26% MySQL) with 11 queries
