diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Fostex Wooden Horn H400 and D1400 Driver (http://www.diyaudio.com/forums/multi-way/129602-fostex-wooden-horn-h400-d1400-driver.html)
Lindell 11th September 2008 07:51 PM
Does anyone have any experience with the Fostex H400 horn and D1400 1" driver?
Sound quality, x-over points, etc
http://i2.photobucket.com/albums/y32/tobbelito/H400.jpg
http://i2.photobucket.com/albums/y32...lito/d1400.jpg
The horn is fairly affordable. $489 at Madisound.
Is the D1400 driver up to par today? Compared to other 1" such as B&C, Eighteen Sound, BMS, Radian, RCF, Beyma, etc. I'm not that experienced in the driver field.
I was think a box something like this with PHL 12":
http://i2.photobucket.com/albums/y32/tobbelito/Horn.jpg
Thank you,
Lindell 11th September 2008 07:54 PM
Horn: http://www.fostexinternational.com/d...f/woodhorn.pdf
Driver: http://www.fostexinternational.com/d.../pdf/d1400.pdf
Lindell 12th September 2008 03:58 PM
:superman:
wixy 19th September 2008 09:25 PM
I'm interested to know about these drivers also. Anyone have any experience?
Monte Verdi 26th January 2009 06:25 AM
This is a very good question. I be lieve if you post this question on the Full Range page you are likely to get an answer.:rolleyes:
Piek 26th January 2009 08:18 AM
here is some info: http://www.soundworks-pa-shop.de/pop...9b79dc7847d229
(oh well, it was posted already :smash: )
Recommended crossover seems to be "higher than" 750Hz, I had a similar combination from RCF and -I- would crossover them at 1000Hz + , if passive. It depends on your desired maximum volume level too. BTW the amount of fostex 1" drivers sold on ebay with blown voice coils speaks for itself imho.
-Micha
Lindell 20th March 2009 02:21 PM
I'll guess it's "Buy 'n' Try" then :D
Resources saved on this page: MySQL 18.75%
