#31 |
Thanks,
how about replacing only the cracked speaker with a new (or used) one ? Should I expect any kind of imprecision ? |
#32 |
Only one way to find out. The original cone might be getting harder and not as flexible as a new unit but that's anyones guess.
I had mine for over 20 years and besides a bit of yellowing seemed as good as new and was still flexible. Once you put the new driver in and play a CD, it's then a used one.
No longer DIY active |
#33 |
gilwe, as long as the TSPs are the same there are no compatibility problems. Just measure the TSPs of the driver.
Best, Markus |
#34 | ||
diyAudio Chief Moderator
#35 | |
Regards Charles |
#36 |
I like closed box too. But this is a little beside the point in mixing with nearfields I guess, because when mixing for judging bass we always do it in high SPL on the main monitors. Normally 12-15 inch.
#37 | |
Regards Charles |
| Proac/Seas woofer surround crack | banana | Multi-Way | 21 | 12th October 2011 08:17 AM |
| Woofer protection for small monitor | Mos Fetish | Multi-Way | 4 | 26th April 2009 08:39 PM |
| Removing woofer from an Alesis Monitor One | ReidK | Multi-Way | 4 | 1st March 2007 03:22 PM |
| fixing monitor | Grandma´s_SUB | Everything Else | 2 | 18th January 2005 03:45 PM |
| Fixing woofer tear? | mikee12345 | Multi-Way | 9 | 30th January 2004 06:39 AM |
| Page generated in 0.09428 seconds (75.35% PHP - 24.65% MySQL) with 10 queries |
