Old 10th September 2008, 02:20 PM   #1
Default Building the Nathan 10 – short version
if you ever wanted to know what it is like to build a speaker kit (in this case the Gedlee Nathan 10) that comes with pre-cut boards, here are the relevant posts (with pictures) from another long thread.
Let's start with the summary:
http://www.diyaudio.com/forums/showt...60#post1605260
Fix variations of pre-cut boards:
http://www.diyaudio.com/forums/showt...77#post1573677
Glue the wooden parts:
http://www.diyaudio.com/forums/showt...94#post1574794
Sanding with 80 grid:
http://www.diyaudio.com/forums/showt...78#post1588378
Filling and sealing:
http://www.diyaudio.com/forums/showt...78#post1589578
http://www.diyaudio.com/forums/showt...04#post1590804
Painting:
http://www.diyaudio.com/forums/showt...84#post1591884
http://www.diyaudio.com/forums/showt...60#post1592460
http://www.diyaudio.com/forums/showt...85#post1593185
http://www.diyaudio.com/forums/showt...90#post1593990
http://www.diyaudio.com/forums/showt...60#post1595860
Fix variations of the waveguide:
http://www.diyaudio.com/forums/showt...00#post1595000
Install internal braces:
http://www.diyaudio.com/forums/showt...10#post1596710
Build the crossover:
http://www.diyaudio.com/forums/showt...15#post1603115
Mounting the tweeter (1st try) / installing drive-in nuts / drilling pilot holes:
http://www.diyaudio.com/forums/showt...00#post1604200
Mounting the tweeter (final version):
http://www.diyaudio.com/forums/showt...97#post1604297
http://www.diyaudio.com/forums/showt...52#post1604352
Putting it all together:
http://www.diyaudio.com/forums/showt...75#post1604975
Good luck with your own project!
Best, Markus
Old 10th September 2008, 07:36 PM   #2
BERENO is offline BERENO  United States
BERENO's Avatar
Thanks for the summary. I have not gone through all of your links, but I am sure they offer all of the relevant info. I have tried going back through the original thread many times trying to find specific bits of information, so this helps.
DISCLAIMER: Im a noob...
Old 10th September 2008, 08:15 PM   #3
Markus,
Hoe did you get such a uniform pattern with the roller?
I always get a line at the edge, or a noticeable difference in the pattern left between adjacent strokes.
Noah
Old 10th September 2008, 08:41 PM   #4
Hi Noah,
you need to use a foam roller with rounded edges. Don't use to much paint and don't press too much. Roll only in overlapping parallel strokes until all paint is equally distributed. Roll over each area a couple of times (> 4). But be fast so the paint doesn't start to dry before you finished. Paint surfaces in the following order: bottom, sides, top, front.
Best, Markus
Old 10th September 2008, 08:51 PM   #5
dviswa is offline dviswa  United States
markus76,
Have you heard it yet? How does it sound?
Dinesh
Old 10th September 2008, 08:53 PM   #6
Markus,
Thanks; I've never tried a foam roller.
"Paint surfaces in the following order: bottom, sides, top, front."
Any particular procedure you used to get the uniformity at the radiused corners?
Noah
Old 10th September 2008, 09:37 PM   #7
No just work fast and try to create no hard edges between painted and unpainted areas. Try to apply a gradient to the rounded sides next to the surface you're working on by varying the pressure you put on the roller.
Best, Markus
Old 10th September 2008, 09:53 PM   #8
OK, thanks, Markus.
When will you get to hear them, and we hear about them?
Noah
Old 10th September 2008, 10:03 PM   #9
They are already running but I first need to finish he subs before I can say anything.
Best, Markus
Old 11th September 2008, 12:01 AM   #10
gedlee is offline gedlee  United States
Markus
Just want to post something so that I am in the loop. Don't want you saying something that isn't true
Building the Nathan 10 markus76 Multi-Way 870 2nd October 2009 07:38 PM
Page generated in 0.12772 seconds (79.63% PHP - 20.37% MySQL) with 10 queries
