For a school project, I was thinking about building a suitcase stereo. That is, a reasonably loud, and decent sounding stereo that can fit inside an old school plywood suitcase. I figure a wooden suitcase is a must, because that way it won't rattle around and it will have some mass. But besides that, will this sound any good, in terms of speaker enclosure? I would use two speakers, in stereo. Should I isolate the two halves of the suitcase so the speakers don't share air-room? What kind of speakers should I use? Car stereo speakers? What should I do in regards to bass response? I was thinking about angling the speakers apart from each other, so they don't face straight forward. The left speaker would point a few degrees to the left and the right a few degrees to the right. Would this help stereo response or just throw the acoustics off and make it weird? I'm not going for super-audiophile sound at all here, I just want something that's cooler than a boombox and hopefully will have a bit more sonic mass. Oh, and how many watts should I expect to be able to squeeze into a suitcase? How much volume before stuff goes wonky? Should I do something like put wadding in the airspace behind the cones? If anybody could help me out, that'd be great. Thanks! |
#2 |
if you let us know your budget, and the internal volume of the suitcase, I'm sure someone can recommend suitable drivers.
The amount of power depends on how you are going to power the amp, - batteries, mains?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
One of Henry Kloss's classics is the suitcase 3 piece speaker. The suitcase can be a typical airtight moulded ABS type. Essentially it has foam compartments for two small speakers, an amplifier and the source, stereo radio or cassette / Cd Walkman. In use these are removed. But the case is also the subwoofer .... An ABS type will not rattle too much used as a subwoofer only. The chip amp type amplifier with active c/o might be difficult. Back to more your original idea see : http://www.partsexpress.com/projects...roject=Podzuma |
| Stereo in/multiple Stereo outs Circuit | MartinByrne | Everything Else | 3 | 7th May 2009 01:11 AM |
| Reprocessed for stereo, Rechanneled for stereo and Duophonic | oldheathkitphil | Analog Line Level | 3 | 29th February 2008 01:20 PM |
| 2 Stereo in's, 2 Stereo out's, USB DAC | djd4n | Digital Source | 13 | 28th August 2004 02:23 PM |
| Stereo speakers with no stereo | klutuk | Everything Else | 5 | 6th June 2004 09:45 PM |
| How do I wire stereo headphones on a stereo tv? | hike1 | Everything Else | 2 | 10th September 2001 02:22 AM |
| Page generated in 0.07215 seconds (74.46% PHP - 25.54% MySQL) with 10 queries |
