HDS 810921 Tweeter with Fullrange Driver (XO-help) - Page 2 - diyAudio
Old 8th September 2008, 10:41 PM   #11
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally posted by Jay_WJ
We may be able to distinguish between different power responses due to coaxial vs non-coaxial driver placement. But in this case, strictly speaking, what we hear is simply different power responses, not the distant sources per se. And I don't think a dip in power response around the xover point due to driver offset is necessarily a bad thing. Some may find it less fatiguing to their ear.
Exactly, I just meant that a coax will behave easier for best coherence using a crossover. I was not referring to the distance but the geometrical benefit. We can do that with controlled dispersion too, a 'la Geddes.
It's not only a dip, if it isn't doing symmetrical stuff or won't add timely in the far field it gives it self away. You are right in principle. There is finite distance that if 2 sources time well are perceived as one. In sound reinforcement they usually digital delay correct at 5 times the woofer diameter or double the cabinet height.
Old 9th September 2008, 09:47 AM   #12
Big thanks Jay,
It will take some weeks, but I will test the Notch filter you kindly provided and see how it goes.
I actually already tried to pair the F200a both with HDS and a Fostex supertweeter (FT96H) using Behringer DCX digital XO and number of different XO points and slopes. When crossing lowish say 4000-8000Hz some sharpness disappeared, but so did also imaging (which is very nice when I run F200 fullrange single handed).
Now I wanted to skip the Behringer DCX all togther and that was reason I asked here opinions regarding passive solution.
Any further comments/views are appreciated and if not, I will report back result when available.
Thanks again
LageB
My experience of using the Peerless HDS 810921 tweeter Jay_WJ Multi-Way 17 12th December 2013 09:30 PM
Peerless 810921 HDS tweeter mods? Updates? sendler Multi-Way 2 25th October 2008 01:26 AM
Horn or Ribbon tweeter with fullrange sharptouch Full Range 1 12th August 2008 05:01 AM
WTB: Peerless HDS 810921 tweeter luvdunhill Swap Meet 1 26th November 2007 05:36 PM
peerless 810921 Tweeter oldbar Multi-Way 1 12th November 2006 10:21 AM
Copyright 1999-2017 diyAudio
