Do any plate amps sold in Australia (or anywhere) include the amp for the sub driver, the crossover . . and also amplification for a single satellite speaker?
Ie effectively take a line level source and provide the basis for a simple active speaker. It would likely be a "non optimal" crossover, but provide simple effective flexibility for HT speakers Thanks
a system that won't go clean and loud is like a nice car that cannot go fast |
#2 |
Or does a normal plate amp take a speaker level source, provide the crossover, provide dedicated amplification for the sub driver, and pass the speaker level to the non sub speaker - avoiding any need for “dual” plate amps?
#3 |
Did it Himself
I'm not aware of any plate amps with more than one amp on board.
Most plate amps take a speaker level source, which could then be split off to a satellite.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Here is one sold by Madisound:
http://www.madisound.com/catalog/pro...roducts_id=369 Regards, Dennis |
#5 |
QUOTE :
Here is one sold by Madisound: http://www.madisound.com/catalog/pr...products_id=369 Regards, Dennis END QUOTE I have that exact one sitting beside me right now. It's a well made amp for the price if you can live with the power output. Mark
Mark |
#6 |
The "mother" HT amp is 100 W/ ch, so while Madisound’s Kiega plate amp has the feature I want, 50 W & 2* 25 W is probably a bit too much of a sacrifice.
#7 |
If you dont mind class D then you might want to check out digmoda at http://www.digmoda.com they do 3way 500w/250w/250w plate amps with dsp crossovers that I've heard are meant to be good. They also support 240v/50hz
#8 |
Thanks discl
The digmoda looks pretty good. Class D can be good, esp for bass. its all in the execution. Though as its just to make the bass better on the side speakers in a HT, importing them wouldn’t be justified. So I probably will just get one of the Jaycar amps. Their 350 w with remote control of both volume and crossover frequency I think was $300, but is now $200 (bought while the $A was up?).
#9 |
I've got 5 of the Jaycar 350w modules and use them with the jaycar 12" kevlar (rebadged hivi http://www.swanspeaker.com/product/htm/view.asp?id=64) drivers.
I found that they sound good with the cheap kevlar drivers but sound horrible with my dynaudio 30w100s (which have a less stiffer suspention). Not sure if this is something to do with the driver's BL or the amp's dampening factor but the dynaudio's sounded very boomy/uncontrolled with the jaycar amps but fine with my other amps. So you might want to see if you can get them on loan and test them with your drivers first. You also need to be aware of the inbuilt bass boost on the jaycar plate amps but this can be eliminated/modified to suit your needs if need be by following the instructions on the following page: http://www.customanalogue.com/critical_q_sub_av_v.htm |
#10 |
Discl
> sounds horrible with my dynaudio 30w100s That’s hard to fathom . . > can be eliminated/modified to suit your needs if need be by following the instructions on the following page: http://www.customanalogue.com/critical_q_sub_av_v.htm Thanks kindly for that info > the inbuilt bass boost I thought that this was 6 db boost at 35 Hz was switchable? Do you know if it’s a peak centred at 35 Hz, or increasing boost as frequency drops (like a normal bass control)?? Thanks
| Help with some plate amps | mazeroth | Solid State | 1 | 14th September 2008 12:31 AM |
| Newby's question about dual coil driver with plate amp | minye | Subwoofers | 6 | 6th September 2007 08:13 AM |
| Plate amps? | Enzo | Solid State | 6 | 29th January 2005 12:31 AM |
| Plate amps in the UK | Matttcattt | Multi-Way | 4 | 5th June 2004 11:04 AM |
| Sub plate-amps in the UK | CaRRiT | Subwoofers | 10 | 14th March 2002 05:35 PM |
| Page generated in 0.12908 seconds (82.22% PHP - 17.78% MySQL) with 10 queries |
