Old 7th September 2008, 05:08 PM   #1
Default Midwoofer help: Vifa P17WH-00
Anybody still has the datasheet for these Vifas (P17wh-00, 8ohm, 6inch)?
d-s-t.com is not up anymore... :-(
Old 7th September 2008, 06:01 PM   #2
Default I hope this helps
I will try to find the freq resp.
G. Luck
Old 7th September 2008, 06:08 PM   #3
Default Freq resp.
... from Vifa, but I know many people tested this one so you if you look around you might find something. JohnK build some spkr with this woofr.
Old 7th September 2008, 08:22 PM   #4
Andy G is offline Andy G  Australia
Andy G's Avatar
I don't remember there ever being a P17WH !
P17WJ, P17WG, P17SJ, P13WH.
anyway, try here http://www.tymphany.com/archives/10
Old 7th September 2008, 11:03 PM   #5
PB2 is offline PB2  United States
PB2's Avatar
I believe that was used by PSB, not sure if it was custom.
Pete B.
Old 8th September 2008, 12:27 AM   #6
I think I might have mistakenly referred to a P17-WH the other day. This is the woofer I was thinking of P17-WJ...
http://www.partsexpress.com/pe/showd...number=297-305
JJ
Old 9th September 2008, 03:11 PM   #7
Thanks for all the replies guys
I'm trying to ascertain if it is indeed a WJ and not a WH...
Will post findings soon
FS: Vifa P17WH-00-08 61/2" Woofers rabidlistener Swap Meet 8 29th August 2007 08:47 AM
midwoofer diffraction mazurek Multi-Way 2 9th April 2006 03:34 AM
car midwoofer vs. home midwoofer sma Multi-Way 1 18th December 2005 03:51 AM
midwoofer 5'' olo111 Multi-Way 9 30th December 2004 05:55 PM
Vifa P17WH-00 Woofer Info? mopus Multi-Way 1 5th November 2004 09:29 PM
Page generated in 0.08749 seconds (74.12% PHP - 25.88% MySQL) with 11 queries
