Hi all,
I got two pairs of polymer coated paper cone midbasses. But the rubber surround was getting unstuck from the cone. So I thought i would try to fix it and applied a rubber-based glue. Sadly, the whole thing got messed up. I then used a cyanoacrylate super glue to stick it up. But the cone is a bit of a mess. Could anything be done to restore its looks? I was thinking some diluted PVA glue would help. Or should I just forget about aesthetics and use them as they are. Thanks and regards, Vivek.
Thank God for DIY audio. |
#2 |
Applying PVA or something else on the cone might cure any visual problems but will give you a different driver with different characteristics.
Basically more mass and less compliance. I have read somewhere that glueing specific addons to the face of the B139 driver was some form of art in designing TL subwoofers with that driver. Experimental and black magic. |
#3 |
So it's better that I live with a driver that does not look so good rather than spoil the sound qualities of the driver, right?
#4 |
You will probably spoil the mechanical properties. But this treatment, if you know what you are doing and are able to experiment, could - in theory - give you a more suitable driver for a particular application.
#5 |
Vivek,
If you apply one or two thin layers of rubber based treatement (only on the cone, not on the surround), the added mass will only eat a small fraction of a decibell on the entire fr range...not audible. I used Visaton LTS 50 with great success (twelve layers resulted in -2db)
crazyhub |
#6 |
I have a pair of drivers which I use for experimentation. I coated the cones with PVA glue and found that the layer is very thin. Yesterday, I went to the electronics market and spoke to a guy who is running a speaker recone business. I asked the guy what glue he uses to stick cones. He even led me to the shop where the glue was available. The glue seems just like the other rubber-based adhesive but easier to use. I was thinking that I would give the cones one layer of PVA or rubber glue and use them for the rear surrounds and the centre channel. I could get better drivers to build front MTM speakers for two channel audio and home theatre. What do you guys think? Vivek
| A 8 incher with a paper cone | stoc005 | Multi-Way | 32 | 23rd February 2010 05:24 PM |
| Manufacturing a paper cone | SunRa | Multi-Way | 16 | 1st July 2008 05:19 PM |
| Paper Cone Strengthening | ttvonau | Subwoofers | 27 | 26th September 2006 02:22 AM |
| Coating for Bextrene cone? | Ouroboros | Multi-Way | 0 | 21st November 2005 08:00 AM |
| ATC cone resin coating | Mikewong | Multi-Way | 14 | 16th October 2005 12:00 AM |
| Page generated in 0.09181 seconds (73.84% PHP - 26.16% MySQL) with 10 queries |
