TransmissionLine speaker ... Sd question ?
The choice of taper ratio has the most effect, it effects the length of the pipe, an SL/So of 0.1 will be shorter than SL/So =1 for example.
As SL/So becomes smaller the TL becomes more like an MLTL or a reflex box - this is probably where the most effect on sound will be? (I haven't built or compared MLTLs)
