Old 1st September 2008, 08:45 AM   #1
Send a message via AIM to unknownuser200 Send a message via MSN to unknownuser200 Send a message via Yahoo to unknownuser200
Default Bookshelf speakers
looking for descent bookshelves speakers for my fronts and rears (surrounds) for my HT setup id rather just have someone suggest the actual drivers them selves and make my own cabinets looking for great response with out losing SQ any help would be great
Old 1st September 2008, 10:28 AM   #2
Nanook is online now Nanook  Canada
Nanook's Avatar
Default way too vague
to allow any to help.
stew
stew -"A sane man in an insane world appears insane."
Old 1st September 2008, 10:34 AM   #3
700$ max for 2 pairs (all 4 speakers)
8 ohms
130 wrms
3 way
hoping for sugguestions on a matching
Tweeters
midrange
woofer
crosser over
do you need any other information? if so feel free to ask and ill help you so you can help me
Old 1st September 2008, 10:48 AM   #4
kmaier is offline kmaier  United States
kmaier's Avatar
I would suspect you're going to have difficulty on this. First, bookshelf and 3-way seem "mutually exclusive" unless your bookshelves are both large and empty. For HT you have several options:
1- Look at Madisound and possibly pick a 2-way Seas kit:
http://www.madisound.com/catalog/pro...oducts_id=8307
2- Look at the Fostex site as they have some enclosure plans with some aimed at HT use... and have some 2-way and 3-way:
http://www.fostexinternational.com/d...ec_enc_1.shtml
3- Build a larger front channel pair and a smaller rear channel pair as your budget may get you parts for 4 speakers but the quality will suffer when spread that thin. This may allow a decent 3-way for front and a decent 2-way for rear, but that's my $0.02. Good luck.
Regards, KM
Old 1st September 2008, 10:53 AM   #5
Tweeters
thinking these http://www.partsexpress.com/pe/showd...number=264-500
midrange
thinking these http://www.partsexpress.com/pe/pshow...TOKEN=44017859
woofer
thinking this http://www.partsexpress.com/pe/showd...number=297-310
crosser over
thinking this http://www.partsexpress.com/pe/showd...Number=260-156
and this cabinent
http://www.partsexpress.com/pe/showd...number=302-753
what do you think?
oh wow didnt notice your post... those are alot nicer than what i posted
Old 1st September 2008, 11:03 AM   #6
kmaier's Avatar
I think you blew your budget already... at $350+ per speaker based on parts listed.... seems your tweeter is the lowest sensitivity as well. Suggest you re-think what you're trying to accomplish and what you're going to use to drive the 4 channels with, etc. A power handling spec. doesn't mean much, but you should look at available power and what overall sensitivity of any particular system is.
Regards, KM
Old 1st September 2008, 11:09 AM   #7
haha ya i reliezed that after i posted... also the reason i went with that tweeter was because of the rest are 6 ohms
powering it is just a standard 5.1 reciever for now
my goals well simple i want a descent sq setup
you have to excuse me i have lack knowledge in home audio
Old 1st September 2008, 11:21 AM   #8
Scottmoose's Avatar
I'm thinking you might've done better to post this in the regular loudspeakers section, rather than the full-range, which is, as the name suggests, dedicated to full-range / wide-band drive units.
However, FWIW, I'd avoid generic XO's like the plague. They're never optimal. For a start all three of the drivers (decent units though they are) that you mention have different nominal sensitivites, which this generic thing isn't going to help rebalance. Next up, it doesn't account for any of the driver's behaviour. If they have a break-up mode in their passband, it's not going to correct for it. Nor will it be providing optimal roll-off slopes -all drivers need to be treated differently.
Moving on to the cabinet, it's way too small to produce any real LF output if sealed with that bass driver, and if vented, it's still too small & will have massive peaking at cut-off. It'll be a bit of a squeeze to fit the drivers in too. Not good.
OK, some general advice: forget 3 way bookshelf speakers. A 3 way tends to need to be large, i.e. a floorstander. There are exceptions, but they're few & far between, plus, it's additional complexity which if this is your first project, you can do without.
FWIW, if I were you, & looking at your limited budget of $700 for two pairs of speakers, I would build Zaph's BAMTM http://www.zaphaudio.com/BAMTM.html or one of his other designs. Zaph's speakers are well recieved & excellently designed. He has plenty of other projects on his site too. Troels Gravesen also has many high quality multiway projects on his site, which you'll find here: http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm several of which should fit into your budget.
Old 1st September 2008, 11:46 AM   #9
http://www.madisound.com/catalog/pro...roducts_id=452
maybe this?
or would i be much better off with the one you posted
Old 1st September 2008, 12:36 PM   #10
Scottmoose's Avatar
I'd definitely go with Zaph's design over the one you link to. For a start, that one is $375 a pop, making it $50 over your budget, nor does it include cabinets in that price. I don't see any response graphs, or XO details either which is setting my alarm bells ringing.
If you want a wild card, you might also fancy trying one of Bob Brines's BR cabinets with full range drivers:
http://www.geocities.com/rbrines1/Pages/FB-16/Main.html &
http://www.geocities.com/rbrines1/Pages/FB-20/Main.html respectively. Fully built they're out of your price range of course, but you should be able to afford to buy the plans from Bob & the components & build materials within your budget easily enough.
CSS 3 way bookshelf speakers sam xt Multi-Way 37 24th January 2012 09:45 PM
ADC 404 Bookshelf Speakers Ed Holland Multi-Way 0 10th December 2008 08:06 PM
Bookshelf Speakers Sammich Multi-Way 5 29th June 2007 08:01 AM
bookshelf speakers - need help ziv_r Multi-Way 1 24th April 2006 11:20 AM
Bookshelf Speakers avguy Multi-Way 32 10th November 2003 10:36 AM
Page generated in 0.12312 seconds (84.09% PHP - 15.91% MySQL) with 10 queries
