Old 29th August 2008, 03:40 AM   #1
ronzeman's Avatar
Default Dayton Crossovers
I'm seeking a 3 way (passive) XO to work with a new system config..using Dynaudio D28-2 tweets....Morel EM1308 mids and a Radford (KEF like) TL bass. I received a quote from a known quality vendor.in Canada..Design and fab...nearly $400.00! (pair). I'm sure they are good..BUT....
Tonight I saw from Parts Express Dayton OEM factory set XO's The 700Hz; 5.6KHz unit should be fine (on paper).
Has anyone used these Dayton XO's ? I read where their tweeter was well reviewed as a good value. I really don't want to spend $400. for an XO The radford XO is a hi quality unit...only it crosses at 500Hz to the mid....a tad low for my application.
Any experience or comments on the Dayton XO's appreciated.
Old 29th August 2008, 04:17 AM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Default Off the shelf
Standard crossovers are not very good solutions to hifi. You're much better off building a properly designed speaker, like those at www.zaphaudio.com
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 29th August 2008, 07:15 AM   #3
Dr. Ram's Avatar
Default Re: Dayton Crossovers
Whether you design a crossover yourself or get someone to design it for you, make sure that it is IN-ENCLOSURE impedance and SPL curves for your drivers that are used to design the crossover. These curves are ideally *measured* in the actual enclosure, but you can get excellent results even if they are *simulated* in the target enclosure. This is why off-the-shelf crossovers are not such a good idea, because they make no assumptions about the enclosure.
-Ram
Old 29th August 2008, 07:28 AM   #4
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
And they make no assumptons about the drivers.
FS: Dayton TMWW Crossovers Slanski62 Swap Meet 1 16th August 2008 01:31 AM
Dayton DA aluminum cone woofer + Dayton DC28f tweeter springy101 Multi-Way 7 15th March 2006 05:22 PM
PE Dayton passive crossovers madpoet Multi-Way 1 3rd June 2005 03:02 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Dayton Crossovers Lusso5 Multi-Way 1 13th December 2003 07:08 PM
Page generated in 0.08027 seconds (72.08% PHP - 27.92% MySQL) with 10 queries
