Non-inductive resistors
Old 27th August 2008, 08:08 PM   #1
cathode_ray is offline cathode_ray  United States
Default Non-inductive resistors
How important is it to use non-inductive resistors in a crossover. I can't find exact values(10%). Are wirewound's not acceptable?
And is non-inductive a wire wound with a counter-rotating layer inside?
Old 27th August 2008, 08:29 PM   #2
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
I have built good sounding speakers with wirewounds in the past and beleave resistor inductance is a lesser issue if it is one at all.
regards
Old 27th August 2008, 08:37 PM   #3
Hyldal is offline Hyldal  Denmark
Just use the standard white ceramic resistors, they are not more inductive than others below 20Khz anyway!!
Old 27th August 2008, 08:52 PM   #4
badman is offline badman  United States
badman's Avatar
Default Less important than cap or coil quality
Still audible? Maybe. Caps and coils definitely are in my experience. You're right that a non inductive wirewound is typically a counter-rotating coil.
Whether it's worth the dollars to go with fancies is another question, that only you and your own ears and wallet can answer.
Most of the time I use the white sandcasts.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 27th August 2008, 09:54 PM   #5
HiFiNutNut is offline HiFiNutNut  Australia
Caps do make very audible difference, even if they have the exactly same capacitance, ESR, ESL. There are other parameters that influence the sound.
For air coils, how would they make difference if the inductance and DCR are exactly the same, or the DCR is padded with resistance to be the same?
Bill
Old 27th August 2008, 10:20 PM   #6
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Inductances of standard resistors and capacitors, and capacitances on standard inductors, are by far low enough to not have any effect below 20Khz. Most standard components have at least 200khz bandwidth.
You can safely forget about parasitic inductances and capacitances on speaker crossovers.
Be careful with placebo effect too
I use to feel like the small child in The Emperor's New Clothes tale
Non-inductive resistorsHide this!Advertise here!
Non Inductive Resistors in Australia Numbat Swap Meet 1 11th March 2007 12:01 PM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 11:33 AM
wirewound non-inductive 1% resistors GAK Multi-Way 18 18th September 2003 04:26 PM
Non inductive caps and resistors Super Parts 5 11th November 2001 11:06 PM
Non-Inductive Resistors rborer Solid State 9 3rd September 2001 09:47 PM
Copyright ©1999-2017 diyAudio
