Old 26th August 2008, 09:10 PM   #1
Default Kef Model 105's
I have a pair of Kef Model 105's:
http://www.kef.com/history/1970/model105.asp
My father purchaced these from new in 1978, he's passed them onto me but my sitting room isn't nearly big enough to do these justice...i think i'd have to get rid of my sofa in order to accomidate them.
I'm looking to sell them on to fund some smaller speakers, but before i do i'd like to make sure they are servicable and worth selling. They are physically immaculate and have the origional covers, they are functioning as my father and i hooked them up and tested them. They are totally unmodified, we even have the origional manual.
I was wondering if anyone here knew what to look for to make sure these are still serviceable as they're 30 years old now, if there is anything that usually degrades over time or anything we should check a little closer before selling them.
Old 26th August 2008, 09:41 PM   #2
get rid of the sofa, they look great....
Check that all drivers are working, and check the condition of the surrounds (Where the cone is attached to the edge of the speaker). That should do it.
Anyone who bought them would probably be well advised to replace any electrolytic capacitors in the crossover, but that's a job for someone who knows about the intestines of these things.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 27th August 2008, 05:53 AM   #3
Moondog55's Avatar
I'm with Peter, buy a house to go with the speakers.
Or sell the sofa
A classic speaker, heard them many, many years ago in England.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 27th August 2008, 06:30 AM   #4
!n 1978 Hi-Fi Choice (UK) ran a comparison of dozens of speakers including the YAMAHA NS 1000M. The 105's streeted the field by a considerable margin. This was no "golden ears subjective fest" but a serious report run/edited by Martin Colloms.......I'm with the others....sell the house. And be grateful.....as the Good Book says!
The electros could be upgraded. Some won't like the cored inductors, and there are a lot of them. At least 8 per speaker. There is also a funny large cap in the feed to the bass unit if I remember correctly. They were looking for 3rd order bass roll off and put a 600uF cap in the +ive line to the 12 unit I think. Many would think there was scope for further inprovement but get into the local KEF site in the UK. They are v.good on this sort of thing. I'll just chase up the site...back in a moment.
Back again. It sound inocuous but try "hifiloundspeakers" in Google and there should be a KEF owners site on the first page. These bods have sections on drivers....forums etc.
Good luck and a jealous greeting from Oz, Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 27th August 2008, 12:21 PM   #5
they were big on complex 3rd order xovers:
http://www.hifiloudspeakers.info/Ana...overIndex.html
Old 27th August 2008, 01:24 PM   #6
SaSi is offline SaSi  Greece
This is not a loudspeaker to sell. Keep them. (And that comes from someone that woudl buy these on the spot). You might some day move to a bigger house and then you will enjoy having them.
The drivers in these are pretty stable over the years. The rubber surrounds hold on well even after 30 years or so, so if the cones are clean nothing more to say about them.
The caps are an issue as always and may need checking - replacement.
Old 27th August 2008, 01:36 PM   #7
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Don't keep them....
Send them to me.....
Andy
PS.. these were the bees knees when they came out.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 27th August 2008, 01:40 PM   #8
Audio Junkie
Zero Cool's Avatar
I had a pair of these! well the 105-II's anyway
I was told that disconnecting the "protection" circuit that the Gen 2's had was the way to go. Mine had a slightly forward midrange sound that compared to my Vandersteen 2C's i didn't like as much. but it was tough to give them up!
Old 27th August 2008, 01:57 PM   #9
AMV8 is offline AMV8  United Kingdom
Phill
I also have some Kef 105's and I think they are a superb speaker.
They may not be as detailed as some more modern speakers with faster mid range units and simpler crossovers but, they I think they give a very impressive presentation of the music that leaves a lot of speakers a long way behind.
I have replaced all of the electrolytic capacitors in mine. I also replaced all the electrolytics in the direct signal path of the mid and treble units with polycarbonate capacitors. I conversed with Kef about this They advised replacing with polycarbonate/polyester caps of the same value plus a series resister of 1 ohm per 10 uf of capacitor replaced to make up for the lost resistence of the electrolytic capacitor. It works although some others have been sceptical of this.
As advised above the 600 uf cap forms part of a low freqency roll off for the base unit to prevent damage to the base unit from frequencies below 20hz or so. If your amplifier and record player are up to scratch you probably do not need this - I have removed these in my speakers.
I have not had any trouble with speaker surrounds as they seem to be a rubber/ silicon compound that has not shown any sign of stiffening or decomposing.
I think the only things you need to do are replace the old electrolytic capacitors in the crossover and tighten ( but not overtighten ) the speaker hold down bolts and then sit back and listen.
Don
Don
Old 27th August 2008, 07:24 PM   #10
Worth checking things, models etc. I've been working on the assumption that they were the early ones. The later 105.2 were a good bit different. I'm pretty sure that the original was a 4th order time aligned model crossover. They were after a 3rd order bass roll off but I suspect that the cross over of Colin's is not the one for phil1012k's unit.
I'll dig around a bit more today.
Model 1 Harderror Full Range 10 10th May 2010 01:35 AM
S.P.Q.R. Model III Harderror Full Range 4 26th February 2008 12:58 PM
JBL Model L55 laced Multi-Way 0 15th November 2004 06:55 AM
NHT Model 1 type Multi-Way 2 25th July 2004 10:35 PM
Page generated in 0.10969 seconds (79.62% PHP - 20.38% MySQL) with 10 queries
