#11 |
AFAIK, "midbass" refers to a midrange speaker with a bit more bass capability than is traditional, maybe a bit longer throw and higher power capability. Those Dynaudio units I mentioned are only about 5" on the cone, but have a 3" voice coil that can soak up a lot of watts. The trick, as always, is to get enough overlap in driver response such that a reasonable crossover is possible. My experience is that few drivers larger than 8" can successfully mate up with most common dome tweeters. The old Large Advent's claim to fame was that they managed to stretch the response of a relatively large woofer up to meet an equally down-stretched tweeter. IMO, everybody who's serious about their listening eventually reaches the conclusion that, though a 2-way can be very good, a well designed 3-way (or more) will beat it on bass extension, vocal quality and probably efficiency. I'm talking traditional boxes here, not electrostatics, Maggies, or groups of drivers like the old Bose. Also IMO, a small set of speakers with a subwoofer qualifies as another 3-way or more system.
I used to be an audiophool like you but then I took an arrow to the knee. |
#12 |
Long time ago I made a 2way fore a friend, with a very nice 8" Seas and a Thiel tweeter, and it sounded quite nice fore a number of years
Now suddenly he doesnt think the mids are clean enough well, thats the price you pay fore using such a big mid Though today I may be able to do better using a notch and so on, but its tricky to get absolutely right...possible, but not easy But certainly, the right 8" can produce quite "musical" sound, not superclean, but nice |
#13 |
Define midbass first would be a good idea.
#14 |
In this case I understand it as a standard hifi driver that does the deepest possible bass from around 40hz up to the high mids around 2.5khz
#15 | |
if we are talking midrange drivers, we are into 3-way systems, right?
In such case I will go for a 4 or 5 inch driver .. woofer But with one important reservation: Very low FS, frequency resonance Quote:
1. Focal ... world's best drivers for hi-fi audio expensive! but worth every penny ![]() 2. Audax ... very good midrange drivers with high efficiency a bot lower in price, but Audax top line is always something extra Lineup Audio Speakers forum - members only can read our stuff!
lineup |
#16 | |
He clearly says 2way in his very first post Fore using a 10" or even 12" midbass, why not consider Gedlees Summa kit, which has the benefit of a compression driver going as low as 1Khz |
#17 |
Single 5" will not give you enough bass in large room. I would not use 5" in rooms bigger than 25sqm. you will probably need a subwoofer
For a large room 2way, I would recommend 2x6.5", 2x7". Or you can try 2x5" transmission line. |
#18 | |
Focal donīt sell drivers to the public except for car audio. Of course some drivers for this destination can be used at home. Audax, they have been into problems and possibly manufacturing of some drivers are kept running by some employees. It has been some notes about this in the German magazine Klang+Ton. Perhaps someone can translate this into English? I canīt read French but I guess the headline says "The site isnīt available right now" Correct? Audax
Without wonderment,no life. |
#19 | |
given otherwise identical perfomance, why largest?
Just because you can't hear it doesn't mean no one can. |
#20 | ||
You mentioned 5" ~ 6" range. I have decided to give 6" drivers a second look, to get a feel for what is affordable in this range. My feeling is that on average, a 6" driver would perform better in the upper midrange, but give up some low end performance when compared to a similar 8" driver. But this makes me wonder - is this generalization founded in fact? Will a smaller driver perform better in the upper midrange section (ie better distortion numbers, smoother response)? Or, is the truth in the data sheet? For example, say I have 2 drivers which are very similar in build. Same cone material, the 8 shall have more motor structure but more Mms so they'll balance and have the same Qts (in a perfect world!). We'll say the 8 can comfortable cover up to 2.5 Khz, and the 6 can do up to 3.5. Now I ask you, at 2 Khz, which will play the tone more accurately? I suppose what I am getting at is, generally, will a smaller driver cover upper-midrange material better than a larger, even if the larger is still within that range? Hehe now I'm rambling! Quote:
You do bring up an interesting point though, of keeping more drivers well within their range as opposed to less drivers reaching to hold hands at the finger-tips around the crossover point. But my feeling is a 2 way system for the 'mains' would probably yield the lowest coloration. However your influence may inspire me to reduce the size of my 'midbass' to something more of a midrange in size. Along with what Blue Wizard said, a 6" should be able to cover the middle band well. *** Thank you to the rest who had something to add - I have read everything, but I am a slow typer, and it is dinner time . Quickly though, to Tinitus thank you for the suggestions but a 10" or greater 'midbass' (or woofer at this point) would conjure crossover tom-foolery beyond my 4th order (at best) mind! Tpsorin, your suggestion of multiple drivers to address SPL limitations sparks another interesting line of debate - which is better many small drivers, or few large? But in this context I am interested in the comparison of the performance of single drivers. Jim |
| Why big port diameter? | Jay | Multi-Way | 22 | 13th March 2007 11:52 AM |
| Port Diameter | jwatts | Subwoofers | 18 | 19th May 2006 11:22 PM |
| Vas and diameter of the speaker | dimitri | Multi-Way | 4 | 27th November 2002 11:36 AM |
