My "Humble Statement" Build
Old 25th August 2008, 11:48 AM   #1
soundengine355 is offline soundengine355  Australia
Default My "Humble Statement" Build
Hi All,
I've decided to start a thread to cover my Humble Statement build as per Tony Gees design.
http://www.humblehomemadehifi.com/Humble_Statement.html
First up I've had to make some minor modification to the enclosure design as I will not be using a CnC machine. I've spoken with Tony and these are well suited/matched for the design.
As per the design "The cabinet measures 1130x314x600mm with an internal closed volume for the two woofers of about 70 litres and gives a –3dB point around 45Hz. Below resonance the output level drops at 12dB per octave as compared to 24dB per octave if it were a reflex enclosure. So there is still quite some energy in the low bass area. The inside walls are lined with 8mm thick felt and the whole volume is lightly filled with BAF. The closed midrange compartment is about 3 litres in volume and tunes the driver to a nice Q of 0,5 with a -3dB point just below 200Hz. This compartment is filled with natural sheep’s wool."
I will be breaking the design into two enclosures:
Tweeter and Midrange Enclosure -
Internal Measurement (HWD): n/a (Approx 3L) *I will fill in the enclosure until 3L Volume is reached
External Measurement (HWD): 340x314 (Bottom) 82 (Top)x507
Woofer Enclosure -
Internal Measurements (HWD): 668x242x435 (Approx 70L)
External Measurements (HWD): 740x314x507
The T/M enclosure will have a curve as per the original design. I will be using 36mm MDF for externals and 18mm for internal bracings.
Heading to pickup the wood this week and hopefully have the woofer enclosure completed by the end of the weekend.
I've attached a "quick and dirty" image cropped from Tony's original. (Without bracing)
Old 25th August 2008, 01:35 PM   #2
inertial is offline inertial  Italy
Hi
Very interesting speaker.
Have you heard the originals? I'm a bit skeptical about the frequency response show . Maybe his particular spacing ( near the wall) boost
the bass and the result is ok as Tony as said hovewar.
But I presume a little different crossover can adjust for a more
"far" and free spacing.
Just a speculation of course.
Best wishes for the work.
Old 25th August 2008, 02:09 PM   #3
No I have not heard the original.
Yes the bass does concern me, the Soup design (http://www.humblehomemadehifi.com/Soup_Ceramique.html) has a -3db of 30Hz compared to 45Hz of the statement, using only a single woofer compared to dual.
Old 25th August 2008, 03:00 PM   #4
Ok,
but I am referring at the entire range 50-250Hz .
In addition he use monster 21 " subs with EQ-XO so 35 or 50Hz
is not a problem imho .
cheers,
Old 25th August 2008, 08:39 PM   #5
crazyhub is offline crazyhub  France
Originally posted by inertial
Ok,
cheers,
Quote from Tony about the first measurement shown on his Statement page:
"The bass seems a couple of dB’s down but listening tests prove deep bass and a firm foundation in balance with the rest of the spectrum. The lower of the two frequency plots is a simulated plot of the percieved energy response. As you can see, the bass is in balance with the rest."
Personaly I own a pair of Tony's Modulus (sealed f-3 = 63Hz): Subs really aren't necessary so I guess f-3 = 45Hz on the Statement is OK except probably in "special" (very big or very small) rooms.
crazyhub
Old 26th August 2008, 04:02 AM   #6
The Soup Ceramique uses the same woofer as the Statement, but its a single vented design. Looks like it goes harder and lower, I'll check with Tony.
Old 26th August 2008, 11:22 AM   #7
From Tony:
The Statement has more "drive", both go as deep. Due to the low impedance of the Statement in the bass it does prefer amps that can give some current
Old 26th August 2008, 11:23 AM   #8
Anyone have any comments on the Statement VS. Ekta Grande?
Old 26th August 2008, 12:44 PM   #9
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Ekta Grande will kick the Statements butt.
That is all.
Old 26th August 2008, 12:52 PM   #10
ahahaha.
Based on?
My "Humble Statement" BuildHide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Humble Statement wigginjs Multi-Way 12 19th December 2007 05:11 PM
Gainclone, the "Statement" amp, help? Sylver300B Chip Amps 35 18th November 2003 03:01 PM
